Greggins_Pro5
- Mazda Protege5 2002
OK - I'm new here so take it easy on me. I have searched the threads but didn't see anything in this category so I'm posting a new one. I've done some nice subtle speaker installs that I will have to post when I get the time.
I'm going insane with my radio upgrade to my 2002 Protege5. I am having an electrical noise problem tied to the engine revs (loud whinning/whirring). Now almost always the problem with this is a bad ground.
I have now installed a ground kit so that the block, throttle, alternator, etc. are all grounded (which improved throttle response greatly - but did not fix the problem). I have run a ground wire directly to the head unit and amps off the grounding block. Additional ground point is underneath the center ebrake module drilled into sanded steel body.
I believe the problem is coming from the head unit. Two different head units have done the same thing. The head unit (Alpine) came w/a noise supressor inline. Unhooking the amps and running only the internal power from the head unit to the speakers still results in whirring w/ engine...esp when lights or AC are on. Yes, my power wires are well separated from my RCAs.
I've poked and tested. The stock unit did not have this problem. In a couple of instances it seemed as if the antenna may have been part of the problem and carrying the noise. I also have XM hookup to the head unit but I don't think thats it. I've ordered new NGK plug wires and plugs but they are not here yet. I've been working on this for 4 months on and off. Has anyone had similar problems? Help!
