ChopstickHero said:I have Ecsta 712 and they have lasted over 15,000 miles so far. and are in good shape, about 60% tread left. Of course, my car is a daily driver and I don't abuse my tires.
If you want longer tread life, you're going to have to look at a different type of tire. Something like a high performance all season instead of a high performance summer tire.pfive said:same ones i have...mines a daily driver also, but sumtimes i take turns hard - because I can!
but im debating weather to get all seasons or take the KUMHO's off around winter and slap some snow tires on...whats more cost effective...
pfive said:I've got kumho ecsta's on my Pfive...can anyone tell me the average treadlife?
im thinking of going to 205's when these burn out, but i would also like to know how much of a hit MPG wise it would give me.
Performance tires are louder than regular A/S tires because of stiffer construction and grippyer (is that a word? haha) compound.rjmhotrod said:Kumho Ecsta uses a soft rubber compound. It has good dry and wet performance and is a little quieter (due to softer compound). But softer compounds will get eaten up quicker (especially if you don't regularly check psi). Plus methinks that driving on asphalt eats them up quicker as opposed to concrete. But that's just my opinion. Thankfully Kumhos don't cost alot so you can afford to replace them more often. So you can spend alot on a tire that will last longer and be a little louder or spend a little on tires that last a shorter amount of time. Either way you're spending about the same amount of money. I personally choose the quieter tire.
pfive said:im going to shop around. can someone give me an idea of what kind of MPG hit i'd take if i went to 205's?
One thing to keep in mind, the treadwear ratings are not an industry standard. The tread wear rating is a number made up by the manufacture, they are all relatively close to each other, but like I said it's not an industry standard.Mmmmmken said:You ought to check out the Hankook Ventus V4's... they have a treadwear rating of 420!!! I've had mine a little over 6 months and they look like they're brand new. I've got the 205/50-16's. A little taller than the stock 195's, but not much at all. Defiantely a bit of a smoother ride with them also, and very quiet.
.paul said:One thing to keep in mind, the treadwear ratings are not an industry standard. The tread wear rating is a number made up by the manufacture, they are all relatively close to each other, but like I said it's not an industry standard.
That being said, you're not going to go out and find a max performance summer tire with a wear rating of 480 or something else wildly inaccurate.
