pfive said:will this oil give me more horsepower then a set of racing stripes?
BradC said:What makes synthetic leak more?
I know, I was asking that in reference to the poster above me (prix, I just didnt quote it). I was trying to get his logic on why it wouldMmmmmken said:Nothing... it does'nt.
prix said:be wary of oil leaks, synthic leaks more easily (gets through places that regular doesn't and if you switch at higher mileage you might start springing oil leaks that would not have happend if you had stuck with regular.)
Think of the lighter pocket as weight reduction!! Seriously though...pfive said:i second that? aside from a larger hole in my pocket, what are the benefits of synthetic?
www.answers.com said:Advantages
The industry recognizes the following benefits for synthetic oils:
Improved viscosity at low temperatures. Mineral oils tend to include wax impurities which coagulate at lower temperatures.
A typical 10W-30 oil remains liquid at -50 C (-58 F)
Better high temperature performance. Synthetic oils have few low molecular weight hydrocarbons which evaporate at high temperatures.
Higher purity
Decreased oil consumption
Reduced friction and engine wear
Improved fuel consumption through better engine lubrication
Longer intervals between oil changes
Resistance to oil sludge problems
Crude oil doesn't have to be used for the production of the lubricants
Some synthetic producers offer extended drain intervals
BradC said:I know, I was asking that in reference to the poster above me (prix, I just didnt quote it). I was trying to get his logic on why it would
I can see that, but 5w30 synthetic has the same viscosity as 5w30 conventional. How can something of the same thickness, be thinner?prix said:From what I have heard (two things)
1. There are degerents in the oil that break down some of the buildup on older engines, some places this buildup acctually prevents leaks
2. Synthetic molecules are slighly smaller, so when an engine has been wearing on reg oil with slighly larger molecules, when you switch it to synthetic the new oil wears differently then the old and if there were any microscopic leaks that were not happening due to the slightly larger reg oil, they will start leaking with the syn.
Both of these things have been told to me by my auto-shop teacher, they aren't just something I made up.
Can't be though, thats what the 30 in 5w30 is. The fist number is its viscosity when at a low temp (0 degrees F) and the second is at a high temp (210 degrees F)..paul said:The viscosity might be different when the two are heated up. The synthetic probably becomes more viscous?
BradC said:Can't be though, thats what the 30 in 5w30 is. The fist number is its viscosity when at a low temp (0 degrees F) and the second is at a high temp (210 degrees F).
The only real downside to synthetic oils is the cost. It is typically two or three times the cost of conventional oil for a good synthetic. Another little-known downside is that switching to a synthetic oil on an old engine can result in oil leaks. Why? Because the detergents in the synthetic oils will "clean-up" the varnish and sludge left by conventional oils. If your engine seals are worn, the synthetic will break down the oil varnish that may be maintaining the seal. So it's not that the synthetic oil caused a leak, it just that it revealed worn seals by cleaning the varnish off of them. Many people have switched to synthetic on 100,000+ mile engines with no leaks, so it just depends on how often you changed your oil and the overall condition of your engine.
