In Memory of Member 1338
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 51
Thread: Protege cabin air filter Installation
  1. #16
    手前の言葉が俺は聞き捨てよう TheMAN's Avatar
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,839
    this is where your cold air comes from people!
    Attached Images Attached Images
    TheMAN
    '01 BJFP MT
    '05 BK3P HB AT
    '16 BMYFS AT
    For Protege and Mazda3 info, come see the Protege FAQ
  2. #17
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,839
    and the blower side where the TXV is
  3. #18
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,839
    and now what is mysteriously inside that black box
  4. #19
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,839
    well, it turns out there are 1 more part that I needed that I didn't buy... and 2 parts I already got that I haven't mentioned yet.. those are the foam seals that goes on each end of the evaporator ducting... and then at the bottom of the box, there's supposed to be a foam insert protector that is taped into the box...
    the seals are:
    GA5R-61-J04 and GE4T-61-J05
    as for the foam insert protector:
    GE4T-61-J29
    this is what will get your panties in a knot... these 3 parts are the most rediculously priced parts of all the other parts I've mentioned so far! But don't worry, the total cost of the whole mod is about 110 bucks for all the parts if you got the trick aldehyde filter and about 70 bucks for just the normal pollen filter... those are approximate RETAIL prices
    I was able to carefully remove the foam insert and use double sided tape to tape it to the new box
    EDIT: at time of writing, parts prices were MUCH lower than now... it will now cost approximately $150 US (retail) for the aldehyde setup... about $30-40 less for just the normal pollen filter setup of course.... I've since redid my setup, and installed a NEW "foam insert protector", but using 3M Super 77 adhesive which is basically what the factory uses: http://solutions.3m.com/wps/portal/3...er-77/Super77/
  5. #20
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,839
    and after I throw everything back together and recharge the system to 1lbs 5 oz of R134a (funny enough, what came OUT of the car was 1lbs 1oz).. I installed the filter... I had ZERO clearance installing the filter... I had to get the floor mats out of the way, and have the bottom corner of the filter touching the floor carpet and I basically had to brute force the filter into the box... then the plug went into place....
    and the end result was: AC works perfectly, and damn cold
    the filter makes me feel like I'm breathing mountain air... no nasty odors at all... it doesn't matter anymore whether I have it on fresh air or recirculated air... it all feels the same
  6. #21
    No words bazooka joe's Avatar
    Donated: $40
    Miata & NEMOC Moderator
    2016 Miata Club, 2004 MSM, 2014 CX5 Touring, Honda 1976 XL 175
    Join Date
    Oct 2002
    Location
    wbee ma to NC 2016 Jinba ittai
    Posts
    21,241
    wow...that is a lot of freaking work! good job!
  7. #22
    Registered Member booom's Avatar
    2002.5 Protegé5
    Join Date
    Jul 2004
    Location
    Los Angeles
    Posts
    319
    Oh wow this is a great jdm/edm upgrade!
    So I don't have any experience working with AC systems. I only have experience with suspension, brake, and intake/exhaust, and sound systems -- the basic rice recipe. What equipment is needed for the project. You mentioned a machine... I'ld like to research this and then go for it. I really want to do this for my P5 -- I don't have allergies but my lady does and she could really appreciate it if I did this.
    Essentially one needs experience using the specialized equipment right? So where would I start? Would it be possible to rent this equipment? If not I'll need to pay someone to do this which I don't like doin. You know I just don't want pay some person to do a poor job because they are careless.
    I've been fucked with too much to let people touch my car anymore. Just recently I got new tires from tirerack.com and I took them into sears to get mounted and balanced. Some air head put one tire on the rim backwards. Then I realized that every tire except for one was rotating the wrong direction! What can I say I'm jaded -- at least I pay attention to what's going on. I wouldn't be surprised if I had someone do this cabin air filter project and tell me I'm all set only to find all the parts I supplied them with in the dumpster behind their shop. I would like to believe my local mazda dealership would be competent but then the other question is how much friggin' flow is it gonna take!?
  8. #23
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,839
    if your AC already doesn't work (freon leaked out), then you can just install this shit before bringing it to a shop to get it recharged/fixed
    otherwise for the DIYer, the best way to do this responsibly is to bring it to a trustworthy shop... tell them what you will be doing, and offer to pay them 20 or 30 bucks to use their recovery machine to suck out your freon... go home, take the few hours to install the shit... go back to the shop and have them recharge it... if your AC is fully working, then you shouldn't have to pay much for the same amount of freon back
    if your evaporator blew up, there's additional info in the FAQ to order the WHOLE unit that has EVERYTHING preinstalled, including the filter
  9. #24
    Transmission Destroyer Focus's Avatar
    MSP and RX-7
    Join Date
    Oct 2003
    Location
    Montreal
    Posts
    2,602
    Alternative method without having to remove anything from the car or recycle freon:
    Open the original box using a xacto blade as such:
    Insert filters as per instructions above:
    Voila:
  10. #25
    Mile High Zoom-Zoom Tom03es's Avatar
    Donated: $20
    2003 Protege ES
    Join Date
    Jul 2005
    Location
    Colorado
    Posts
    1,830
    ^^I like that!
    2003 Laser Blue Protege ES-
    Mods: Injen CAI; MSP struts and springs ; Racing Beat rear sway bar + AXR Clunk Fix ; MSP STB; tinted windows; ceramic coated OBX header; AWR 88 durometer front & rear mounts and side mount inserts; MSP taillights; UR underdrive pulley; Racing Beat catback; 17x7" Enkei RSV wheels w/ 215/45-17 General Exclaim UHP tires; DaveB gauge rings; EBC Greenstuff front brake pads; Hayden transmission cooler; GT Spec 4 pt ladder brace; Medieval Motorsports alternator, water pump & power steering pullies; Autometer oil press, water temp, oil temp, trans temp gauges; VTCS-less intake manifold; Lentech Street Terminator VB; AutoExe lower arm bar; catted SLS mid-pipe
    Cardomain
  11. #26
    Registered Member R-X-R's Avatar
    2003 Mazda Protege ES
    Join Date
    Nov 2007
    Location
    Liverpool, NY
    Posts
    925
    this should go in the "how to" didnt even knew there was a filter lol.,.
    2001 Mercedes C240 [DD]
    2003 Mazda Protege ES [Sold]
    1987 Mazda RX-7 GXL [Project]
    2000 Mazda Protege LX [Sold]
    1998 Saab 900 S Turbo [Sold]
    1993 Mahindra Jeep CJ 500 - [Sold]
  12. #27
    Riddle me that! slavrenz's Avatar
    2001 Mazda Protege LX 2.0
    Join Date
    Nov 2008
    Location
    Ames, IA
    Posts
    2,298
    Quote Originally Posted by Tom03es View Post
    ^^I like that!
    lol, how the hell did it take someone 4 years to figure this out
  13. #28
    Donated: $20
    2003 Protege ES
    Join Date
    Jul 2005
    Location
    Colorado
    Posts
    1,830
    Probably because not having a cabin air filter is really no big deal so no one really cared enough to actually look into this. Edwin's approach is pretty involved with the freon capturing and probably turned everyone off. Focus, on the other hand, just bought a Familia from Japan that probably came with the filter and after some close inspection of how the filter setup differs from the non-filter setup, he realized an incledibly simple way to fit it.
  14. #29
    Join Date
    Nov 2008
    Location
    Ames, IA
    Posts
    2,298
    thanks - it wasn't really a literal question though. On the brightside, this brings the part costs down to around $40.
    And I disagree that not having a cabin air filter is no big deal. Where I live, there is a lot of road construction going on right now, and I have to drive through it every day, which fills my car with lots of dust and weird smells. This is just one of myriad examples, but the point is that I think they do make a big difference.
  15. #30
    Dirty Old Man Be11ydawg's Avatar
    Donated: $20
    2002 Mazda Protege 5 - Midnight Blue
    Join Date
    May 2004
    Location
    Tomball, TX
    Posts
    138
    So the parts required would be the Cooling Unit Seal, License Plate Holder and the Cooling Unit Filter to do the install if I have read correctly.
    Jim's 2002 Midnight Blue Protege 5
    Interior / Stereo: DaveB brushed rings, Kartboy shift knob, billet rearview mirror, Leadfoot's 2 pod instrument gauge, MAM billet door lock cover, Eclipse head unit with 6-disc changer, 2 - JL Audio 10W3v.3 subs with JL Audio 500/1 amp, JL Audio XR525-CS separates in fronts with JL Audio 300/2 amp, Audiobahn AS65Q speakers in rears. Dakota Digital voltage gauge (brushed aluminum with blue readout) mounted in custom CF face plate with head unit
    Exterior: RX7 clear bumper lights, billet shorty antenna, custom mesh grille powdercoated silver, MX-5 17" wheels
    Engine: Injen short ram CAI, Magnecor plug wires, Magnaflow catback exhaust, MP3 ECU, Dexter's hood strut kit, Kartboy shifter bushings, 1sty grounding kit, OBX UDP, AWR motor mounts
    Suspension: Tein S-Tech springs w/ Tokico Blue struts, AWR 19mm rear sway bar, GT SPEC front tie bar and ladder brace
Similar Threads
  1. Nasty Smell!
    By Strata in forum Protege5
    Last Post: 07-22-2005, 09:59 AM
  2. Cold Air Intake vs. Cone Filter
    By PGFracing in forum Mazda Protege
    Last Post: 06-28-2005, 08:54 AM
  3. Request a K&N air filter.....
    By SilverM3s in forum Mazdaspeed3
    Last Post: 08-15-2004, 09:47 PM
  4. How to clean Monster flow air filter
    By mushi in forum Mazda Protege
    Last Post: 07-19-2004, 10:02 AM
  5. Forsale Blitz air filter for MSP/P5
    By Autox MSP in forum Global
    Last Post: 11-14-2003, 05:41 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
