early626 said:
I have an 81' 626, I have been surfing the net finding other people who have modded theirs, I haven't found anyone in the states that has as of yet, mostly australia and a few other countries, I am curious if anyone knows what parts can interchange with little or no modification, or with mid level mods, the ones that i have seen have had 13b motors that are N/a or Turbo or Twin Turbo, that is what I would like to do, however, a more realistic approach for me financially would be to find a good miata donor and use the motor out of it and suspension parts to aid the handling of my car, the cool thing about my car is it is already RWD so the possiblities for engine, tranny swaps are nearly endless, i once thought about putting a small block V-8 in it, that would be entertaining, but I would like to make it a kick ass sleeper and corner carver, some road racing future maybe if funds come through. Just wanting to know if anyone has had any experience modding these earlier cars. Thanks for any help guys and gals.
I currently have an '82, 2d coupe that I'm rebuilding. I owned a 1979 back in 1980 when they first came out and when i saw this one, had to have it for old times sake.
As far as compatibilities and crossover parts/pieces, engine parts are the same as the ford courier and mazda b2000 of around the same era. the rear axle is the same as on the RX7 of the same era as well. I haven't confirmed this yet but am told that the shocks and struts off the '81-83 RX7 GS and GSL (Not SE) are the same. If you want to add disc brakes locate an RX7 GSL SE model. I have an '83 GSL RX7 disc brakes and the axles are the same. Much of the drive train of the 626 was the same as the first Gen. RX7's.
As far as interchanging Miata parts, well unless you're able to do a LOT of chassis and suspension fabrication, you wont be able to change out the rear suspension directly. The Miata has independant rear suspension so you'd have to fabricate hangers for the a-arms and work out mountings for the rear coil-over struts. The 626 has coil springs and shocks, a lot different than the Miata. Front suspension on the Miata will be equally difficult to swap. I have two Miata's so I've been looking at the same things you have. I had similar thoughts.
Engine/tranny wise, not sure what would need to be done to make the mounts. I haven't looked too closely on that yet. I have access to a 12A which I am told is a fairly simple swap. That remains to be seen. You could probably look at Grannyspeedshop
http://www.grannysspeedshop.com/ for their v8 conversion for the RX7. There might need to be some structural mods to make it work. A big block v-8 will upset the handling just due to the extra weight. So in a straight line it might be fine, but through the twisties, it might be a tank. Some RX7 guys have opted for the Chevy 4.3L V-6, still plenty of HP but a little lighter package and easier and cheaper to find. Common in Chevy Astro vans and S10 pickups.
One big issue is aftermarket rims. The 626 as well as the 1st gen RX's have a unique bolt pattern of 4x110 with a 20mm offset. Yeah try finding something to fit that.
Anyway what I've found is that 4x108 also known as 4x4.25 rims WILL bolt right up with no modifications. But beware of the FWD rims offsets, most are 35-45mm and will cause the rim to hit the struts and shocks. If you look for rims that will fit the late 70's to mid 80 mustangs, they had 4x108 and some had 20mm+/- offsets, The newer Ford Focus is the one that uses 4x108 but not sure of the backspacing, most likely it's in that 35-40+mm range. It looks like the car can easily take 17 inch rims, but 16's are going to be my choice primarily because I hate the big rim 4wd jacked up look and also I don't want to ride on rubberbands, but that's personal preference more than anything. Personally anything bigger than 17's will overwhelm the small car.
That's all I can think of right now.
Good luck.
