Roywhitep5
- 2007 350z
my engine whistles like a tea kettle at 5k rpm. thoughts?
Yeah.. that happens to mine also.Roywhitep5 said:my engine whistles like a tea kettle at 5k rpm. thoughts?
I dunno if it is the radiator...Rusty said:Vacuum leak? Idler pulley, alternator or some other bearing? I've personally never heard a radiator whistle.
Roywhitep5 said:i think its only when the car is accelerating
magnumP5 said:This is off-topic but I saw the title and figured I'd ask. When I turn my car off I get this weird "winding-down/whistling noise" that almost sounds like a turbo spooling down. I've had the car for nearly a year now but I've just resently noticed it. Is this a normal thing? Oh, by the way, I have a CAI and a catback exhaust but I've made sure everything it tight and that there are no gaps. Thanks, and sorry to threadjack.
Ah, I get it, thanks. I also have a whistle under accleration. Since the CAI causes a whistle at shutdown, couldn't it also be causing this whistling?zverg said:It's the CAI.. just think of it as breathing a sigh of relief when you shut off the car.
I also have the 5k RPM whistle.
Roywhitep5, do you have an underdrive pulley? Mine started making the sound after that.
Well it doesn't sound bad, actually kinda like a really small turbo spinning type of whistle.ke20sprinter said:Then it may not be the engine...maybe something came loose that is vibrating in the wind, make sure everything is tied down...
If all else fails, crank your stereo louder (thumb)
WiL
