BoostedMP3
- #4 Laser Blue Mica MP3
100 Posts Biatch!!!
t3ase said:I've towed the MSP with mi madre's ES.
MPNick said:Towing with a turbo four[if it is] does put more strain on the engine because you will be lugging it. You will stay in boost long, the boost will build sooner. This will heat up your exhaust manifold sooner, higher and longer. Maybe you will detonate more.
As for the trans. I do not think you will hurt the trans but the clutch will take the hit. Most trucks can tow more with an auto then a stick. A 4 or 5 speed trans with a convertor will get you better pulling power then slipping a clutch.
If your trailer has brake it will not hurt your system if it is adjusted right.
Go slow and do not tow for to long at any one time. Make sure you have new clean oil in the engine and gear lube in the trans.
I know alot of who towed with the 2.3 turbo and never had problems. Be smart and take it slow, you should be fine.
TampaSport20 said:Do you really wanna read about this kid getting in an accident because you told him it was ok ???
Stormtrooper77 said:All you need to do is crank up the boost to get power to pull the 2300lbs. Also make sure you're boosting in 5th while going uphill so that you are able to keep constant speed and keep up with traffic.
Hope this helps. Please let us know how it goes.
MPNick said:I would try the other way. With load your EGTs will climb very fast and very high. That is the danger of towing with a small turbo4 and to much trailer.
hex2bit said:Like I said, common sense.
chuyler1 said:00zmde towing his 2300lb trailer...
http://www.msprotege.com/forum/attachment.php?attachmentid=58420
