yellerandahalf
- '03.5 MSP(Yellow!)
Ok y'all, I've been doing some calculations on fuel delivery to investigate why I'm hitting 100% duty cycle at 6500rpm. I've figured out that I only need like a 150lph fuel pump to achieve 350bhp, so that's not it. I took a look at what my calculated injector size would be for this app, and found it to be 63#/hr! the WRX's are only ~42#/hr! so that's it. now, I'm not near 350bhp yet, so I don't need quite that much, but i will. Anyways, injector flow rates are calculated at standard fuel pressure, 3 bar (about 44.1psi). Now, it is common practice to increase fuel pressure to compensate for the size of your injector's virtual penis. assuming a completely linear increase in flow rate due to pressure, 4-bar would give me 580cc/min at 4 bar(58.8psi). The generally-accepted max pressure injectors can handle is 70psi, so I'm nowhere near that. but can the rail and fittings be pushed that hard? does anyone know? Also, does anyone have any data on how the WRX injectors react to pressure increase? perhaps a curve? that would be awesome. also, those of you who have put in adjustable pressure regulators and such, where did you run your fuel lines to? I have several -6AN fittings, and lots of -6 line to work with. Thanks for your help!
-Mateo
-Mateo
