VersaTuner - tuning software for Mazdas
Page 3760 of 3773 FirstFirst ... 27603260366037103750375837593760376137623770 ... LastLast
Results 56,386 to 56,400 of 56583
Thread: What have you done to your P5 today?
  1. #56386
    Registered Member 915_P5's Avatar
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,111
    What l.e.d.s do you all use for the fog lights.
    MSP HEADLIGHTS, MSP DOOR SILLS, MAZDASPEED AXLE BACK, S2K ANTENNA, REAR WIPER DELETE, FRONT PLATE RELOCATOR, TEIN COILOVER/STRUT SUSPENSION, OBX HEADER 4-1 W/ FOULER TRICK, K&N DROP IN FILTER, SPORT SHIFTER BASE, FRONT LIP, DIY FOGLIGHT MOD, COMPASS/TEMP MIRROR
  2. #56387
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    166
    Installed the corksport 3rd link bushings, was not fun. The grinding and drilling method made it soo difficult. Best way imo, was to saw the bolt on the thicker bolt head just inside to avoid that yoke problem. Did notice significant reduction if not complete lack of play when engaged in any gear.
    2002 Mazda Protege5 Pure White
    MP3 Flashed ECU | Mishimoto Radiator/Shroud | MS Door Sills & Shift Knob | OBX Short Shifter with CorkSport Bushings | Goodridge SS Brake Lines | CorkSport 3rd Link Mod | MPV Wiper Stalk & Tribute Nozzles | S2K Antenna | Cabin Air Filter Mod | Rear Bumper Guard with Matte Black Rear Valance | 205/55R16 Kumho Ecsta 4XII on 03 P5 Wheels
    Among the fair amount of maintenance work done.
  3. #56388
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,111
    MP3
    Installed my first set oF hids, and also replaced the rubber clutch line do to it leaking and having no pressure to slave.
  4. #56389
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    166
    Quote Originally Posted by 915_P5 View Post
    Did you get a ss clutch line?
  5. #56390
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,111
    No, an autozone special clutch line. I may go with one later on.
  6. #56391
    Registered Member
    02 protege5 ES 5dr
    Join Date
    Jul 2016
    Location
    Calgary,AB
    Posts
    232
    Quote Originally Posted by stormkyori View Post
    Oh nice, that pin can be a bother lol. Did you go with the bronze oil or urethane bushings ?
  7. #56392
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    166
    Quote Originally Posted by horseflesh View Post
    I just think it makes no sense to try and grind one side or drill if you can just cut thru the bolt itself and give you room to push out the bolt from both sides. You risk damaging it or in my case bend it a little in which i had to use a rubber mallet to straighten it out because it would no longer pivot freely. yeah i did the whole corksport bronzeoil kit.
  8. #56393
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,111
    Mp3
    replaced washer motor, finally finished the cabin air filter install.
  9. #56394
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    166
    Mp3
    Same as my parts for that are on the way.
  10. #56395
    Registered Member mspeedP5's Avatar
    Donated: $20
    '02 Protege5
    Join Date
    May 2004
    Location
    Vancouver Island, BC Canada
    Posts
    1,249
    Removed power steering pump and took it to a fabricator to add a 1/4" flange on the outer edge of the pulley.
    - Mark -
    '02 Sunburst Yellow P5
    With just a little power adder...
  11. #56396
    Registered Member
    2003 Mazda Protégé5
    Join Date
    Jan 2018
    Location
    NM, USA
    Posts
    16
    Changed the oil, super gross and dark. I'm also having some rear wheel noise I need to further investigate. Unsure if the calipers are sticking or bearings or shot. Or both :/ Makes noise when rotating either wheel. Didn't have time to dive deeper but I'm hoping for a simple solution.
  12. #56397
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    166
    Did the cabin air filter mod. Lining up that second one inside was a little frustrating but with some maneuvering I got that sucker on there. I didn't even have a filter in there and my heater core is filthy.
  13. #56398
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    413
    I decided to practice metal cleaning, polishing, and painting. I intend on cleaning/painting my valve cover and my new IM (when I get it), so to get a feel for it, I painted my engine hoist hook.
    Here's a few pictures + a little write up about it.
    2002 Mazda Protege5
    ■ Sunburst Yellow ■ Black Rear Valence ■ Injen Cold Air Intake ■ Racing Beat Catback Exhaust ■ Moog Front Endlinks
    ■ Megan Racing Rear Strut Tower Bar ■ Racing Beat Rear Sway Bar ■ Mazda6 Front Big Brakes ■ Foglight Deletes
    ■ OBX 4-1 Headers ■ MP3 ECU ■ VTCS-less Intake Manifold ■ Mishimoto Aluminum Racing Radiator + Fan Shroud
    ______________________________
  14. #56399
    Damian Dpwhitehead1's Avatar
    Donated: $25
    LX, MSP 1145
    Join Date
    Jan 2005
    Location
    Owings Mills, Maryland
    Posts
    9,259
    Quote Originally Posted by mspeedP5 View Post
    what do you plan to accomplish with this? just curious
    Be happy!
  15. #56400
    Registered Member
    02 protege5 ES 5dr
    Join Date
    Jul 2016
    Location
    Calgary,AB
    Posts
    232
    So yesterday new alternator went in. Today new belt again...
    Really hoping it was me being simple and not tensioning belt properly, otherwise its new water pump time.
Similar Threads
  1. Did something today
    By shoogerfree in forum Mazdaspeed3
    Last Post: 12-28-2008, 07:42 PM
  2. CEL came on today
    By elderlycoffee in forum Mazdaspeed3
    Last Post: 10-26-2007, 03:44 AM
  3. Anyone today?
    By Joost27 in forum Miata Lounge
    Last Post: 08-11-2007, 10:29 PM
  4. Got my MSP today!!
    By jersey_emt in forum Mazdaspeed Protege
    Last Post: 08-14-2003, 12:57 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
