Who has a 99-00 Factory Service Manual
TampaSport20
Potential Scammer!
2000 Protege DX
As stated above, I need some help...
Already posted another thread similar, but I'm looking for a different response, hence, this thread
The Correct, FULL FSM should have vacuum diagrams, showing how ALL the vacuum lines are routed
I need to check some vacuum routing
If you have one can you please come forward and scan these pages
obviously I need the 1.6L ones, std. emissions, manual transmission
I looked it up and this is what I found. I hope it helps.
I have the factory manual, all 5 zillion pages, i just dont know how to navigate too well.
I provided you with the only diagram of the vacuum lines. I have attached a scan from the index. If you could be more specific I might be able to help. Sorry I cant find what you need.
I use my Haynes manual more than the shop manual because its easier to use. Haynes has alot more pictures.
I just want to explain that the manual separates emmisions, fuel, intake and so on and each of those has separate mini diagrams . You would have to be more specific or I would have to scan a crap load of pages. I glad you figured it out though.
