Bigg Tim said:Jeph--the TM coming on at 1psi or so isn't all that bad. There's not enough load on the engine to do much harm. I have mine coming on around 1-2psi and it's been fine for a long time. If you set it too early, then it may come on in a higher gear where the loads are a bit greater. How often will you be at that specific moment where you are running 1.5psi for an extended period of time?
Yeah, thats a good point, whats yours set at?
