Titanium-99
- 2007 Diamond Graphite Infiniti G35 Coupe
The other day I took off my heat sheild to polish it up and found that my exhaust manifold is cracked down the center of the manifold. The crack is about 4 inch's long and has two smaller cracks on either side of it. I didnt think much of this because it looked like it was just on the surface and now a week later the car is driving like crap as if it has a exhaust leak. I have checked all the connections on my exhaust and found no leaks , all bolts and nuts were tight. This would leave me with only one conclusion that the exhaust manifold is cracked all the way through and causing the leak. I spoke on the phone with my friendly mazda service dept and explained the situation I also informed him that my car is pretty heavly modded and he said no problem bring it in we will get it replaced under warranty which was kind of shocking to me.So my question to other members is, Has any one else found there exhaust mani cracked? have you taken it to the dealership to get replaced? Does any one know if there is a TSB out for this particular problem? If you have a cracked manifold or have had a cracked manifold please share your story and how it turned out for you.
