During Luke's (RoguePro5) engine swap this evening, we were buttoning everything together and I went to connect the last few connectors. Among those was the crank position sensor connector.
However, the connector was different than the one installed on his original engine. The donor engine was removed from a 2002 sedan of some breed. Lukes P5 is also a 2002. Does anyone have any idea as to why the connector is different? Is there anything different about the CPS? Everything else connected correctly. The donor engine was mated to an automatic transmisson (while the oil pans are different, everything internally is the same) if that makes any difference.
Suggestions?
Suggestions?
