Little Beavis said:Do they still cover this when the warranty has expired?
Don't know, my cars at the dealer as we speak. They will get to it around noon and I'll let everyone know what they say.
Dexter said:Resistor pack on the A/C? There is no resistor pack on the actual unit itself. There is one in the system to control how hard the blower blows...hmm.
trbomp5 said:(help) My A/C only works in position 1 and 4. In 2 and 3 the light goes out.....QUOTE]
I've never heard of positions 1,4,2 and 3????? (dunno)
Have you tried 69? That always seems to work for me (2thumbs)
Pro5Monkey said:trbomp5 said:(help) My A/C only works in position 1 and 4. In 2 and 3 the light goes out.....QUOTE]
Ya that one works just fine, I should have just stuck with that one!
SkinnyJoint said:if yours is an 02 wouldnt it be out of warranty anywayz? unless you bought an extended one which why would u do that on a salvage?
I dropped it off like 3 hours before they opened.SkinnyJoint said:ummm not trying to be a dick here but you should have known your car was out of warranty. even if you had an 02.5 it expired end of may as mine did. and i even brought this up to you before, you should of had them check it while you were on the lot before you dropped it off!
brealmp3 said:So when are they suppose to give you an answer?
ssmp5 said:I took my panel apart last night and cleaned the board with electric cleaner and also took the fan switch apart and cleaned all the crap out of it. Wa-la, now my sheeeet works again!! It wasn't that hard to take the whole control unit apart and it only took about 45 min. start to finish. You guys might want to try it before wasting money on another board.
Dexter said:There is a wire that goes to the ECU that you can ground (or +12V, i cant remember...dont take my word for it...) and it should turn on the A/C, BUT I think the control board may override this....not sure...i gotta dig up some of the bad wiring diagrams.
