Airbox Mod
Duct tape for performance modding! hehe....
Not to get off-topic.. but cat-back on MS6 = worthless.. unless you are willing to spend that money ONLY for a change in sound.. the stock cat-back setup is MORE than what the car can use... Now.. removing the cat.. or upgrading it.. would be a big step...
CP-e is working on a turbo-back system i'm pretty sure... wait for that... before you make any decisions
Raynman said:
It's a matter of personal preferance. I duct taped the box so that it only draws air from the bottom.
The lower half pulls from fender air(cold) where the scupa puls from the heated air from the radiator. both air is filtere thru filter before it goes into the car so if that was an issue don't worry. If you are afraid of rain water then don't worry either. unless you are driving thru water up to the lugnuts you shouldn't hydrolock from this perticular mod alone.
