Is there a way to build something like this, or buy one that is cheap? I don't need a display, just something that will switch between high and low voltage to tell one way or the other(doesn't matter if open/closed are high or low).
I know you can get OBD scanners that will tell you this when hooked to a laptop, but I just need something that will send a signal when in closed loop or not. Is going through OBDII the only way? Is there some wire that tells this, or do you have to have complicated circuitry to communicate with the ECU and ask what mode it is in?
