Have relined 100's of P5 rear brakes.....................most wear the inside pads down first on both rear wheels.....................if the outside pad is say 75% remaining and the inside is 5% ...............then you have a prob................but at 60k if the difference is only marginal .............thats the norm. Most single piston brake set-ups always wear the inside pads more because they are the first ones to contact the rotors..............then the caliper slides over on its anchors and forces the outter pad into the rotor. Brake systems with fixed calipers and multipal pistons wear the pads more evenly because the inner and outter pads move at the same time as you step on the pedal [both or all pistons move together applying even pressure to all pads] ...................nature of the beast............single piston calipers are cheap but not as efficient.Greg S said:Need to know if anyone has run in to this. I was doing the 60,000 mile check up on my wife's P5 and the rear inside pads were worn almost all the way down. I've never run in to this before and wonder if anyone knows what could be causing it?
mastertech said:Have relined 100's of P5 rear brakes.....................most wear the inside pads down first on both rear wheels.....................if the outside pad is say 75% remaining and the inside is 5% ...............then you have a prob................but at 60k if the difference is only marginal .............thats the norm. Most single piston brake set-ups always wear the inside pads more because they are the first ones to contact the rotors..............then the caliper slides over on its anchors and forces the outter pad into the rotor. Brake systems with fixed calipers and multipal pistons wear the pads more evenly because the inner and outter pads move at the same time as you step on the pedal [both or all pistons move together applying even pressure to all pads] ...................nature of the beast............single piston calipers are cheap but not as efficient.
Lord_Zath said:I think there was a TSB for rear brakes sticking for p5's...
LZ
Z
Tough to say what is causing your problem?????????? A dragging caliper should be easy to spot................how about your caliper sliders.......are they seizing \ bent .............this could cause the caliper to stick and not slide properly when the brakes are applied.................in turn not applying even pressure on the outside pad. Without having the vehicle to examin it is hard to say...................look for something common to both rear calipers. As for the rear pads there should be a spring in there to keep the pads off the rotors when they are not in use.Greg S said:Thanks mastertech,
It's the first problem, still had 50% on both inside adn outside fronts adn outside rear with the inside rears worn all the way down. Went and checked the e-break tension and it was fine, actually a little loose so I tightened it up to spec. Can't say if the rear tension was too tight or not, as I automatically backed them off to push the piston back for pad replacement. I do know it's set correctly now as I made sure of that. Any best guesses on why they were worn like that or is the rear bias the best bet? I also noticed that there were no springs to push the rears apart so apparently it's just using surface pressure from the disc. Is that correct?
