programming your remote control for mp5
Alpinejwl
Banned
2002 Protege5, 2005 Mazda3, 2006 mazda5
I got this instruction from a guy who I bought a remote from on ebay. I wanted to see if any of you guys have done this before. I wanted to make sure that this is the correct insturction to program my new remote before trying it. Also, since the instruction said that I have to have all remote presents (including the one that is working), I wanted to make sure I don't **** it up otherwise I will have no remote.
Mazda keyless remote programming instructions:
NOTE: A maximum of 3 remote transmitters can be programmed.
1)Obtain all remote transmitters.
NOTE: Any existing remote transmitters not used during programming will
become inoperative.
2)Remove key from ignition switch.
3)Close all doors.
4)Open driver's door.
5)Carry out the following procedure within 24 seconds:
A)Turn ignition switch ON and back to LOCK position 3 times.
B)Remove key.
C)Press and release driver's door courtesy light switch 3 times.
D)Ensure doors lock and unlock.
E)If not, wait 40 seconds and repeat procedure staring with driver's door
already open.
6)Press any butoon of each remote transmitter twice.
7)Ensure doors lock and unlock after each remote transmitter operation.
8)If not proceed as follows:
a)Press and release driver's door courtesy light switch once.
b)Ensure doors lock and unlock twice.
c)Repeat procedure starting with driver's door already open
Here's the instruction sheet that came with my remotes
