Any reported fuel oil dilution issues on the 2.5 turbo?
With the Honda CRV turbo oil fuel dilution causing so many problems. I was wondering if Mazda had any issues with their turbos?
There's a post on the CX-9 forum that had they results from oil analysis done by Blackstone Labs. Fuel in oil was less than 25% of normally acceptable levels. That one report indicates the 2.5T doesn't have a fuel dissolution problem.
Because they engine was out for 3 years and no real issues reported is why I bought they CX-5 2.5T without worrying about potential unknown engine problems. Same goes for the reliability of the A6 reliability with the increased torque. I'd say the power train is solid.
It's the first time to me seeing an oil analysis on a 2.5T with oil dilution issue. On the other hand we did see several reports that when they check the oil level on their 2.5T, the oil level is over the "MAX" mark. It could be caused by over-fill from factory, or the oil dilution? Only time can tell.got a not very promising analysis: https://www.mazdas247.com/forum/sho...ution-Issues&p=6647360&viewfull=1#post6647360
Got an analysis for my 2.5T from oil analyzers... aaaand 5% fuel in 3350 miles.. ouch! (nailbyt)
The oil happened to be a cheap Castrol GTX magnatec. If I understand correctly, it should not affect fuel levels? Better oil should have just maintained the viscosity better.
Possibly more relevant fact was that I ran only 87 gas this time, as a low interval experiment
Switching to 91 and AmsoilOE, will check again in 3500.
At the same time got a report for a q5 with 70+k miles. Only 1.6% over 9500 miles. Most of the mileage was rough due to carbon buildup.
I don't agree Castrol GTX Magnatec is a "cheap" (bad) oil though. It's a full synthetic oil and 5W-30 is the recommended viscosity. It's API SN PLUS/ SN, ILSAC GF-5, and GM dexos1 Gen 2 certified.
I also don't believe 87-octane gas has anything to do with your oil dilution issue either. We shall see with your next oil analysis which should confirm many things. Please keep us posted.
And I put your UOA to the following CX-5 thread and hope you don't mind:got a not very promising analysis: https://www.mazdas247.com/forum/sho...ution-Issues&p=6647360&viewfull=1#post6647360
