XM reception sucks. Any add-ons or mods?
2016 CX-5 GT. Deep, holy crap that is dark, blue.
I'm guessing the XM sat antenna is in the sharkfin? Has anyone played with OEM sat radio antennas before? I wouldn't mind getting something better.....even in areas that trees aren't covering 100% of the sky, it still cuts out!!!! Worse than any vehicle I've had with XM. For a mid-top end car, I'd expect better. Is there a computer hack to lower the squelch?
2019 CX5 Reserve AWD
Doubt there's a mod to fix the reception. Reception is a factor of your location. S/Xm only has two satellites, most of the reception is covered by ground transmitters located atop buildings, towers, etc. If you're away from big cities you're relying on the satellite(s) and with two coverage ain't gonna be great.
Be interesting to know your general location.
Delaware. My Mini had only minor issues, as does my R1200RT in woody areas....but the CX5 seems to cut out when there are only minor trees around. I live in a pretty woody area, and drive a good amount through that and open areas. Same travels, different car. And I can tell the CX5 is just....lacking. Maybe it's just mine, but that seems odd to have issues from one person to another. :-/
That's funny, I'm in northern Delaware. XM in our Honda will cut out in wooded areas also but not to the point of distraction. The Honda has a twisted antenna that's about 10 inches high, much different from the shark fin. Maybe the shark fins are not as receptive but look better. You may want to talk to the dealer and verify that the fin is the actual XM antenna. I don't have XM in my CX-5 so I can't compare reception between my Honda and Mazda.
bmninada
Contributor
2016 CX-5 AWD GT+iActive Soul Red
Check Channel 19 - Elvis something. Way, way back when I was associated with XM, this is the channel we used to test signal strength.
2017 CX5 AWD Touring
XM radio is and always has been POOR quality radio. FM is much better in terms of sound quality. The problem with satellite is that the BANDWIDTH is severely limited and therefore quality goes down the tubes.
bmninada
Contributor
Don't know, but in XM I am getting significantly richer sound than FM and almost as good as HD Radio. This across multiple channels of music. I have purposefully tried the FM channels which have a XM equivalent.
2018 CX-9AWD GT
Not just you. My car has the same issue, XM craps out ALL the time, for darn near any reason. Overpass, trees, adjacent buildings, canyons, etc. The signal is very weak in this car.
It's about bandwidth, bandwidth, bandwidth....
http://xmfan.net/viewtopic.php?t=115557&postdays=0&postorder=asc&start=0
That's WHY Pandora streaming at higher BIT RATES will sound a lot better than lower streaming bit rate music. Spotify offers high streaming bit rates but it requires a subscription.
Manufacturers try to cram a lot of sound/data but that hurts the quality of the sound. That's why BluRay sounds and looks better than regular DVD's. BluRays can handle larger amounts of data on the disc while DVD's cannot.
bmninada
Contributor
I think overall all the antennas in cx5 are weak. I enabled Wifi and even my puny 8 yr old phone latches on to signals in the same location which the car can't even find.
MikeM.
MoMo
2013 Mazda CX-5 Touring AWD 2.0L
I don't know. My 2010 F-150 has such weak signal it will crap out just from a few trees. Lord help you if there are skyscrapers or even a natural canyon. I find it unusable in my truck. I guess the problem lies with XM Radio (unless you happen to live in an area of the country with good reception).
2016 Mazda CX-5 Grand Touring W/Tech
No problems with our 2016. I live in a pretty rural areal and Im sure it's relying purely on satellites most of the time. Cuts out occasionally in a heavily tree lined canyon I sometimes drive, but far less than my 2016 Honda Accord or my previous 2010 Accord.
It's under warranty, might mention the bad reception to the dealer and see what they might be able to do.
2018 CX-5 Touring
I certainly think the FM antenna is weak. Actually it may be its location that's the problem. Haven't found it yet.
Why have an antenna signal amplifier if you can't provide it with something to amplify?
Well yeah, but I'm talking actual signal quality here. I already know sound quality is in the shitter. :(
