- 00 Protg LX
SO... the whispers of the interwebs, says these seats are direct bolt in. the answer is yes and no
so i pick up this set of WRX seats off facebook for well under $100. since i was unsure if they world fit or not. they didn't need to be prefect not going into a show car just a rallycross car.
so the front feet are what you need to modify. I used a pair of channel locks to match the angle of the stock seats. than I used a drill and egged out the hole side to side because the front feet are narrower. When you go to install you may need to pry a bit to get the front to match the holes. The rear feet bolt right in nothing need to be done
I change out my seat belt clip to the Mazda out but the Subaru one works fine just a matter for swapping the connector. That what my plan was but I need to unbolt the clip for my eye hook for my corbeau harness
finale thought: I love theses seats they are comfortable IMO. they hold you in place in the turns far better than the OEM seat.
when installing it easier to have a 2nd person to help with seat placement, also put all 4 bolts in loosely before cranking down fully
these seats are from a 03 WRX. but 02-07 WRX, STI, Impreza or Forester seats SHOULD fit. not sure but i believe the outback ones are different.
