Water leak
2010 Mazda 5
I have had water leaking in the lift gate window, I think. I have seen water on the back cargo floor and once on the third row seat back. It seems to come from the trim around the window not off the window. Has anyone had this issue? Looking for advise before l take apart the lift gate.
2010 Mazda 5
Not sure. I pulled the center brake light an put a little silicone around the bolt hole seals and the hole for the plug. I'm not sure that is where it is leaking. I'm concerned it may be the seal around the glass.
Next time it rains I will check.
2008 Mazda5 GT
Something must have happened to cause this.
Just a thought, did you happen to back-up into a lower clearing that tugged at the antenna base? I know someone who backed their CRV into low area and ripped the antenna base loose, which caused a slow leak. Fix it by using a faux shark fin cover (AM/FM reception suck but they don't use it). Looks great.
2010 Mazda 5
The leak is internal to the lift gate. It drips from between the glass and plastic. Not that I would say it is impossible. Also, no, I have not backed into anything.
2012 Mazda 5
take the plastic off the back door, take the plastic off he roof by the gate and look...
get inside the car and ask someone to poor the water from a hose and watch...
You can also drop the headliner a bit at the back and see, just need to remove a bench of plastic bits and door seals.
Remember that leak could be coming from anywhere, like a sunroof and run down to the lowest point.
2010 Mazda 5
So the silicone did not work. I will start taking things apart the next chance I get. After I replace the clutch master cylinder, for a second time.
I have the same issue, Poureda bucket of water over the tailgate and straight away it made its way inside the car. I was about to remove the brake light but just read your post doesn't look like that'll help. My next step is probably to remove the whole door, not looking forward to that task. Did you ever find a solution? Cheers
2008 Mazda5 GT
Check the grommet for the hatch door. Pull off (snaps) the plastic trim on the rear roof. Have someone drench the base of the grommet (outside) as you push and pull it (inside). If the car is old, the gasket around the grommet is likely getting dry/brittle. Opening and closing the hatch ay move it a little. movement/not perfect fit = water entry. Water comes in form there and and the plastic trim carries it off to the sides, down into trunk.
2010 Mazda 5
Current solution has been too live with it. After looking at having to take the door off to remove the interior panel I just have not been motivated. I can put in a new clutch, struts, and CV axles but not take off the hatch. What if wrong with me.
Top
