2003 P5 2.0 MT 170k miles.
The transmission has just been swapped out for a used one because one of the shaft bearing failed and damaged the gears and case beyond repair.
The new transmission was apparently out of a 83k miles 2003 Mazda Protege with 2.0engine. It is possible that it was from a standard protege and not a "5".
The 2 sensors in teh transmission had different plugs on them, so we simply swapped the sensors over from damaged box to the used box. Everything worked and the
car drives and shifts fine with the used box in place.
the problem is that now, the speedo does not read at all.
Does anyone know if the speed trigger wheels are different in these boxes? Could the sensors be incompatible? The case of the 2 transmissions was identical obviously as it went in with no problems.
anyone have any insight for me?
Thanks,
Todd
Thanks,
Todd
