Tire Pressure
2016 and 2017 Grand Touring
I now have a 2016(9.000 miles) and a 2017 both Grand touring(love them both) with 19" tires. Just wondering what air pressure others are running. I am not looking for a soft ride.
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
Basically, how high can you go with no issues and/or alarms
Typically, if you go higher than the factory recommended spec, you'll get improved mileage while sacrificing traction and increasing the risk of tire, rim or suspension damage when you hit potholes or curbs.
2014 Mazda3 S GT auto, 2008 MX5 6-speed
...and wear out the tires' center, faster.
shadonoz
SkyActiv Member
Contributor
State of Jefferson
2017 CX-5 GT AWD+
Just the opposite. Lower pressure increases those dangers.
Look on the side of the tires - the max. inflation pressure is listed there. Do NOT go any higher than that.
You will also want to note the date code. Do not use any tires older than 6 years from the date code, no matter how much tread is left. This is also a safety issue.
Date code is probably not an issue on a daily driver, but be sure you didn't pay for old tires.
Inflation pressures can varied to influence vehicle handling (e.g. for racing); traction in sand, etc; and gas mileage. The manf. puts an optimal number on the sticker based on what their lawyers tell their engineers...
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
Yep, so does higher pressure. I didn't mention lower pressure because OP isn't asking about underinflating the tires.
shadonoz
SkyActiv Member
Contributor
State of Jefferson
2017 CX-5 GT AWD+
Not unless it's ridiculously high, too high to reasonably ride on. It's not an issue.
Ottawa, Ontario
17 Mazda 6 GT
Hey, I think you should all go with the factory pressure that they come shipped with.
You know, around 55 psi or so.
I mean, the dealers don't lower it when they do their delivery inspections, so why should you......
shadonoz
SkyActiv Member
Contributor
State of Jefferson
2017 CX-5 GT AWD+
Just experiment. You won't hurt anything. See what feels best to YOU on the roads YOU drive. Looking for a consensus here is like wrestling a greased pig. :)
Pitter
Pitter
Contributor
2020 CX-5 Signature Azul Metalico
I imagine the door plaque's stated 36psi presumes frequent highway travel at 70 mph or more. In my case my daily travel is is at much lower speeds including city stop and go but also about five kilometers of rough unpaved road. Because of the latter I am thinking of dropping to 34psi for slightly more comfort.
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
Your idea of "ridiculously high, too high to reasonably ride on" is not the same as everyone else's. That's why I didn't specify a particular psi. As you increase/decrease psi from the recommended spec, the risk of damage increases accordingly.
Top
