- 2011 Mustang GT
This thread is designed with the sole purpose of stopping n00bs from asking that infamous question:
"HaI i'm new...I gotz a MS6 -N- I waHnt to m4ke iT teh fa$t3r! H0w do aye?"
Fear not! This thread is designed to be a simple one stop solution to answer this question. My goal is to break it down for those on a budget with recommended setups from members who have been here for a while, including myself. The goal is to provide a cost effective solution and give you noticeable gains, and update this as parts become available in the future.
I encourage any member to PM me experiences/suggestions, but please keep unnecessary chatter to a minimum. I will ask the 6/MS6 moderators to please clean up this thread as they see fit.
When installing these parts, it's important to save your stock parts. Should you need work at the dealer, you can swap most(or all) of them out and take it in to avoid having warranty issues.
NOTE: This is merely an opinion. These are not absolutes set in stone, so please do not jump me for telling you something that you may not agree with 100%. I assume no responsibility if you void your warranty based on suggestions from this list.
BASIC BOLT-ONS
Goal: Simple install, quick gains, cost-effective
Cold Air Intake/Short Ram Intake
Brands: AEM, Mazdaspeed, Cobb, ProtegeGarage, Corksport, CP-e
Gains: 10-20hp/10-30tq (est.)(depending on model)
Price: $175-400
Install Difficulty: 2/5 (grab a few beers and go to town)
Bypass Valve (BPV)
Brands: Forge, TurboXS, Turbosmart, Greddy, HKS
Gains: Holds boost pressure better than stock
Price: $150-350
Install Difficulty: 1/5 (5 minutes, literally!)
Turbo Inlet Pipe (TIP)
Brands: CP-e, Cobb, RPMC (no longer available), Protege Garage
Gains: 6-7hp, improved turbo response, spool at lower RPMs than stock
Price: $100-200
Install Difficulty: 3/5 (1+ hour, several hard to reach spots)
Top Mount Intercooler (TMIC)
Brands: ETS, TRZ (?), Street Unit, AutoExe
Gains: up to 20hp/tq
Price: $500-800
Install Difficulty: 1/5 (swap the old for the new under the hood, right on top)
Plug 'n' Play tuning solution:
Brands: Cobb
Gains: Depends on setup
Price: $695
Install Difficulty: 1/5 (plug into OBDII port)
Test Pipe (TP)
Brands: Street Unit, Turbo XS, SLS
Gains: 10 hp (est.) smoother turbo response
Price: $100-150
Install Difficulty: 1/5 (4 bolts under car, swap cat out)
Cat Back Exhaust System
Brands: Magnaflow, Corksport, ETS, CP-e
Gains: ??????
Price: $600-1000
Install Difficulty: 2/5 (get under your car and swap some pipes!)
Rear Motor Mount:
Brands: AWR, Street Unit, CP-e
Price: $80-130
Gains: More fluid shifts, better overall driveability
Install Difficulty: 2/5 (2 bolts, need a jack to hold motor up)
Short Shifter:
Brands: TWM
Price:$130-200 (depending on options, with or without bushings, Stage 1 or 2)
Gains: Shorter shifts between gears, less slop in shifter
Install Difficulty:2/5 (1+ hour, removing some interior trim temporarily)
Q - What should I buy for XXXX amount?
A - Depends on what you're looking for. This is the tricky part. Some people go for all power, where others want a good balance of things. Below are some standard suggestions for people based on several price points; $500, $1000, and $1500.
1 - The $500 'Package'
2 - The $1000 'Package'
All of the above plus:
Happy Modding!
added by Wannabe:
For additional information on these and some other mods, please see the Performance Mods Thread
BASIC BOLT-ONS
==========Engine:==========
Price: $175-400
Bypass Valve (BPV)
Price: $150-350
Price: $100-200
Price: $500-800
Brands: Cobb
Price: $695
==========Exhaust:=========
Test Pipe (TP)
Price: $100-150
Gains: ??????
Price: $600-1000
==========Drivetrain:===========
Rear Motor Mount:
Price: $80-130
Short Shifter:
Brands: TWM
==========Suspension:==========
Lowering Springs:
Brands: Eibach, Tein, Tanabe, H&R, RPM, AutoExe
Price: $200-350
Gains: Improved spring rates, lower stance
Install Difficulty: 4/5 (need time, tools, and an alignment when finished)
Price: $200-350
Front Strut Tower Brace (STB)
Brands:Corksport, AutoExe
Gains: Stiffened front suspension
Price: $125-250
Install Difficulty: 2/5 (just a few bolts under the hood)
Rear Sway Bar (RSB):
Brands: AutoExe, Whiteline
Price: $180-350
Gains: Stiffened rear suspension
Install Difficulty: 3/5 (under the car, removal/reinstallation of newer sway bar)
Price: $125-250
Price: $180-350
- AWR motor mount - $80
- Cobb SRI - $190
- SU test pipe - $110
- Forge BPV - $155
- Whiteline rear sway bar - $180
- H&R springs - $240
- Cobb turbo inlet - $165
- AutoExe STB - $245
Happy Modding!
added by Wannabe:
