Tapping vacuum line for boost gauge
Hi folks. Can you provide photos of an intake manifold vacuum line that I can use to connect my boost gauge for 2007 Mazda CX-7? Thanks a bunch!
I found the vacuum line from bov to intake manifold. However is normal for it to show negative pressure? Its reading -18 psi at idle. Any suggestions?
rsvinylgraphics
2008.5 MGM MS3
Contributor
2008.5 MS3
is it normal for it to show negative pressure? It’s reading -18 psi at idle.
That sounds about right to me. If the turbo is not forcing air into the engine, the engine is sucking air which is what causes vacuum. A negative reading on a boost gauge is merely telling you how much vacuum your engine is pulling.
Is there a better place to tap? That doesnt show negative boost?
I mean. That is more negative pressure Than I would have guessed. -18. And only maxes at +5. Would that mean +23 total boost or just +5? I wold think just +5 but that is not stock then. I asked and there is no way to recalibrate it. Any thoughts?
Top
