Spacers installed
2019 CX-9 Sig
Installed spacers in January. Thought I would contribute some to the forum. Here are few pics. 25mm front, 32mm rear.
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
Looks great! A slightly wider stance does wonders for the CX-9.
2019 CX-9 Sig
Really changes it up. This looks perfect but from some angles I'm thinking 20/25 might work better. I think I might give it a try in the summer, depending what I do with wheels.
Here is side by side stock vs spacer.
2019 CX-9 GT
Just curious if you ended up trying a different spacer setup? I'm looking into spacers and wondering which size to go for. Did the 25mm fit without modifying the studs? Would 20mm work without modifying as well? Also where did you buy the spacers from?
Sorry for all the questions just trying to get as much info as possible. Thanks.
Mazda CX-9 Grand Touring 2016
How much wet road slop gets thrown up on the sides? Do you think it'll throw winter road sand (here the "sand" is about the size of an olive pit) against the paint? Will the optional splashguards for the car do an adequate job?
Top
