Slop in driveline
Made in USA and Free Shipping on all orders shipped inside the US.
V
SOLD 2002 Protege5; Current 2008 CX-9 Grand Touring
Hi, All.
My 2008 CX-9 GT AWD has a problem that is not uncommon, but I need your thoughts on the cause.
When I dip into the accelerator moderately aggressively after i coast for a second (not enough for the car to slow down), I often feel and hear a thump from the rear. It is almost as if the driveshaft connections had some play. Doesn't happen if I ease back on the accelerator.
Any thoughts on most likely culprits would be appreciated. If I can check myself, I will. If not, shop recommendations in Queens / Nassau County in NY would also be appreciated.
Thanks,
ZoomFive
G
Guest2018
Hi, All.
Thanks,
ZoomFive
Could be transmission slippage. Could be differential backlash. The driveshaft is supposed to have a little rotational play at the differential but not tons. The drive axles should also have a slight amount of play - you have an AWD vehicle, no doubt. Yours is a 2008. Mine is a 2017. They both do the exact same thing. I've test driven multiple post-2016 CX-9s and confirm the same at low rpm/low throttle settings followed by moderate acceleration - like when approaching stop signs and then slowly moving through the intersection.
I guess, if you are hearing any whining associated with acceleration distinctly coming from underneath the vehicle then I'd be more concerned. I'd also be concerned if the "thump" turns into a "bump" from the rear. If you can put it on a rack and get under the vehicle, check for fluid leaks near the rear diff and where the drive shaft connects to it. Check the transmission case exterior for the same.
V
Hi Cessna CJ4.
Thanks for the reply. It is definitely a thump. So if I let off on the gas at a low enough speed (like 5-10 mph) and then step abruptly back on the gas. I will hear a thump and get a bump from the rear. At that point, the tranny hasn't downshifted.. I can repeat this consistently by doing what I described. Other than that, there's no real rear whining or noise. I think I saw some dark spot on the diff casing. Could a bad pinion seal or pinion bearing cause this? I wonder if there's a problem with my spider bearings?
ZoomFive
V
2007 Mazda CX9 GT AWD
My wife's 2007 CX9 GT was exhibiting the same symptoms and upon inspection, the rear driveshaft support bearing/bushing was shot (rubber was broken) and the rubber mount on the passenger side of the rear differential near the snout had failed also. I replaced both and it fixed all the thumping when re-applying the throttle.
V
Thanks lincoln32v. I appreciate you weighing in. I'm glad you got it sorted and it wasn't anything more major. I have to go in for the airbag recall soon and may have the dealer look at it. Can you tell me ballpark on cost to address both of these?
Zoomfive
V
Zoomfive
I purchased mine on ebay and installed myself
The diff. side mounts are around $150/ea. for the part only. You can buy just the bushing if you have access to a press for only $20/ea.
https://www.ebay.com/p/Mazda-L2142868XB/1857687836?iid=252607652251&rt=nc&opts=opick&thm=1000
https://www.ebay.com/itm/Differential-Mount-Bushing-Rear-Upper-Febest-fits-08-12-Mazda-CX-9-3-7L-V6-/252581439676?_trksid=p2385738.m2548.l4275
The downside do the driveshaft bushing is that you can buy just the bushing for around $30 but I couldn't find any info on how to separate the driveshaft sections. There are no bolts and it appears to be pressed together. Eventually, I gave in and just replaced the whole shaft from the dealer for $550! (boom04).
https://www.ebay.com/itm/Drive-Shaft-Support-Bearing-3-5-L-For-Mazda-CX-9-/122116404465#rwid
https://www.jimellismazdaparts.com/products/gb/Mazda/CX-9/SHAFT--PROPELLER/1956224/KG0325100D9U.html?partner=googlebase_adwords&kwd=&origin=pla
V
Damn... the entire drive shaft?!? Did the drive new drive shaft have the support bushing / bearing attached?
-Zoomfive
G
Guest2017
Hi Cessna CJ4.
ZoomFive
Hey, ZoomFive. Checking back to see how this turned out for you. It has been a few months since you first reported the problem on this forum. Spider bearings, Pinion seal or Pinion bearing - all potential culprits based on your report. It looks like you have the 2007, so it does not have the newly designed extended range lock-up clutch inside the torque converter - the new one has a multi-disk clutch design and that's causing some issues in a handful of the newly designed CX-9s from what I read.
What was the end result for you?
Interesting.
Latest threads
Latest resources
Top
