rim peeling?
2018 Mazda CX-9 GT
do the stock rims for 2018 cx-9 GT's have some kind of material on them that is applied like a vinyl wrap/sheeting? i noticed on my front right rim what looked like a possible scratch, but upon closer inspection, it's a almost like a little flap that is sticking up. if i push it in, it stays down but eventually comes up. It looks like if I were to pull on it, it would peel off. i've attached 3 pics below
2014 Ford Explorer Sport, 2009 CX9(Wife's)
That's likely the lube they use to mount tires.
They apply it to the tire bead before installing on the rim.
I think it dries out and turns rubbery like that.
Nothing to worry about besides cosmetic. You should be able to peel it off.
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
Grab some tweezers and peel it off. I had the same stuff on my CX-9, just a bit less of it than you. It's likely just a plastic wrapping applied on the rims to protect them on the boat ride to port.
Latest posts
Top
