Ran into my first issue with my 2016 CX-5 GT (kind of a odd one)
Scythe024
'16 CX-5 GT
So on 3 separate ocassions now I have noticed a puddle of water on my passenger floor mat. Luckily I have all weather so it didn't soak into the carpet. The first time it happened I didn't think anything of it. It rained a few days ago, maybe my passanger stepped into a puddle and brought it in. I dried it up. A few days later my bro was riding passanger side and noticed water again. Hmm it hasn't rained in nearly a weak now, puddle is unlikely, but I cleaned it up. Today another few days after the last incident, again water! I can hear it when it happens usually, but not catch it. it's enough water that you can hear it sloshing around. Anyways I checked today and the top part of the foot area was a little wet, so I am guessing it is coming from their, most likely from the A/C.
I called to set a appointment up today, but got the machine. Hopefully it is an easy fix
2014 Mazda CX-5 Touring AWD
Some years ago I had the heating element leak water in a Toyota. This eventually caused the engine to overheat.
Please make sure your water level is not dropping.
Like you said, it can also be from the A/C, if the drain is clogged.
CX5 GT-R
-Make sure it's not coolant from the heater core.
-Make sure the sunroof drains are working correctly, if you have a sunroof.
mazdadude
ZOOOOOOOOOM ZOOOOOOOOOM
'16.5 Mazda CX-5 Touring
Yes sure looks like your AC condensate tube is blocked somehow... there have been several reports of this lately...
2019 CX5 Reserve AWD
Easiest thing to do is run the car for a few minutes with the A/C, preferably on a warm day. Put the car in park on level ground and look under the front near the passenger side wheel. See if you can see any condensation dripping down. On hot days there should almost be a steady stream. If you see no water than more than likely the drain hose is blocked. If you don't want to bother with it take it to the dealer.
13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
Kind of weird a 16 model would clog up like that. Too new to develop moldy clogs in the drain tube. Perhaps the tube is blocked from outside of the car (underneath). That or an object fell into the tub.
mazdadude
yes I agree. Wondering if a piece of plastic flashing is blocking either up in the drip tray, or perhaps inside the plastic elbow where it exits the car..?
madar
Contributor
2016.5 CX 5 Touring AWD, 2015 SCION XB
Ran into this issue as well, felt some water collect on the tray below the fan which eventually leaks onto the floor. I'm not parked under any trees or anything so this is kind of weird.
attachment.php
Check the DIY section on how to remove the blower. (2 wire clips and 3 screws).
I would then inspect inside the inlet connected to the blower with a flashlight. Let us know if you can see the condenser/evaporator coils (sorry always get them confused.) inside that inlet. Said coils could be blocked and/or having ice accumulated thus creating a small pool of water when it melts. Then check if the drain tube is clogged. A product such as KlimaCleaner can keep the aluminum fins clean and help clean out the drain tubes. You may even used a long stick or something to unclog the rubber drain tube.
madar
Contributor
I would then inspect inside the inlet connected to the blower. Let us know if you can see the condenser/evaporator coils (sorry always get them confused.) Said coils could be blocked and/or having ice accumulated thus creating a small pool of water when it melts. Then check if the drain tube is clogged. A product such as KlimaCleaner can keep the aluminum fins clean and help clean out the drain tubes. You may even used a long stick or something to unclog the rubber drain tube.
it's under warranty, going to the dealer. 22,000 miles...shouldn't be having this problem.
^ Oh ok. Yeah let dealership handle it. Any issues with your AC not getting cold?
2019 CX-5 GT 184 2.2 twin turbodiesel auto - Sonic Silver
I*m not sure that it*s in the right place for condensate. Has it ever had a windshield?
madar
Contributor
Replacement? No. Forgot to add that it only happen during heavy rain....could very well be a windshield leak. A/C gets cold. Doesn't that tray look like its designed to catch water?
^ no that's just a cover panel
May want to check next time it occurs again is if the cabin filter is wet. That's the only way air/water could get in externally. Internally, a clogged drain tube could be an issue.
