I thought I had found threads before that answered these questions, but I'm having a hard time finding the info now, so here it goes. I plan on lowering my car in the spring with an Eibach Pro-Kit and Tokico Blue's. I will also be putting on a new set of wheels (17x7 / 215.40.17). I'd like to get as much info as I can before I do this so that I can avoid running into any complications. So, here are my questions...and feel free to add in any extra advice that you think would help.
1. Are there any special tools, parts, or hardware that I should have on hand, other than a good set of tools?
2. I've heard that the endlinks can be troublesome to remove. I'm thinking I should have an extra set of endlinks on hand in case I need to cut off the old ones. Is there any reason why I should go with AWR adjustable endlinks over another set of OEM endlinks?
3. Is there anything I should do to avoid getting the clunk that some people get after changing out springs/struts?
4. After everything is installed, I plan on getting a good alignment. Last time I had one done at Midas and all they could do was make sure it was within the acceptable range. I'm looking for settings that would are good for a daily driver (good gas mileage, low tire wear, low road noise) but still ok for an occasional auto-x or club drive and lots of spirited driving. Is there a good place to go to have this done, or specific settings i can ask for?
I know this is a lot to ask, but your advice and input will help me out a lot. Thanks for taking the time to read all of this.
