• Welcome to Mazdas247. Membership is free and offers many benefits, please Click Here to learn more, thanks!
  • Mazdas247 is an Amazon Associate and earns from qualifying purchases.
Problems removing brake booster... help please.
2010 Mazda CX9 AWD
Hello Everyone,
I'm trying to replace the brake booster, but it's getting stuck on the pipes that go to the heater core through the firewall. Do I need to separate the booster from the master cylinder before I try to remove the booster? The master cylinder won't separate easily from the booster. I removed the two bolts that secure the brake master cylinder to the booster, but the cylinder is stuck to the booster. Any tips or trick would be GREATLY appreciated.
Thank you,
Max
2010 CX9 AWD
I have not done the job and I'm only commenting based on past experience. There has to be some kind of connection to the push-rod to deal with as well. I don't know how this is done in the CX-9 but I suspect that there is another connection related to this that is causing the issue. I'm pretty sure you need to decouple the booster from the master cylinder to complete this job.
2008 CX-9 Grand Touring
Did you get it completed - I am ordering a new brake booster and master cylinder today and plan on tackling job this week. Any tips?
If you have not figured it out already, there are 2, 10mm nuts that hold them to the firewall. If you remove those then you can move them out of the way enough to get it out.
Weekly Poll: Interested in the MX-30?
  • Yes
    Votes: 9 31.0%
  • No
    Votes: 7 24.1%
  • I want an Electric CX-3, 30, 5, 8 or 9
    Votes: 13 44.8%
  • I want an Electric Mazda2, 3, 6 or Miata
    Votes: 1 3.4%
Top
