New Product Release! SKYACTIV 2.0 and 2.5L Oil Catch Can Kits!
Made in USA and Free Shipping on all orders shipped inside the US.
jbarone
Authorized Vendor
09' & 2011 MazdaSpeed3
Details:
During everyday engine operation, blow-by gases, as well as oil vapor from the engines rotating assembly, pass through the PCV valve and are routed into the intake for the engine to burn off. Before ever making it into the cylinders, some of that oil mist and other contaminates adhere to the backside of the hot intake valves. Over time a thick crust forms significantly reducing performance and potentially leading to a costly cleaning or repair. This is especially a problem for the 2.0 and 2.5L motor because, there's no fuel (Direct Injection) passing over the valves to wash and keep them clean. This is why an OCC is a must have for the Mazda SkyActiv motor.
As the PCV gases enter the catch can a pressure drop occurs. The oil then begins to fall out of suspension as it flows through a series of 3 perforated filter plates. As the gases flow through the plates, the oil sticks and the gas is all that reaches the outlet at the top of the catch can. Oil that accumulates on the filter plates runs off and is collected in the bottom.
The JBR Oil Catch Can is conveniently mounted in the engine bay on the passenger side firewall. The large 5/8" drain hose and easy to operate drain valve make emptying the catch can a breeze at each oil change.
Throughout the life of the catch can, the perforated filter plates will never break down, need to be cleaned or be replaced.
Application
  • Mazda 3/6 and CX5 with 2.0 & 2.5L SkyActiv G Engines
Features:
  • Designed and Manufactured in the USA
  • Entirely constructed out of 6061 aluminum
  • Precision TIG welding of all components
  • Large 5/8" easily operated drain valve
Includes:
  • 1 Oil catch can
  • 135" of 3/8" polyester reinforced oil, fuel and chemical resistant hose
  • 1 Drain valve
  • 20" of 5/8" PVC drain hose
  • 5 zip ties
  • 3 1/4"-20 X 1/2" stainless steel bolts
  • 3 1/4"-20 Nylon insert lock nuts
  • 2 Stainless mounting brackets
  • Installation instructions are available in our support section
  • Shipping is free in the US & our Hassle Free Lifetime Warranty is included
Details:
Application
Features:
Includes:
  • 1 Oil catch can
  • 1 Drain valve
  • 5 zip ties
@jbarone I have a 2020 CX5 with the 2.5 non turbo engine. Please quote and if possible include shipping to PuertoRico. Diego
Top
