• Welcome to Mazdas247, the 24/7 Mazda Community and Resource. Learn about the benefits of becoming a Member here.
  • We're an Amazon Associate and eBay Partner. We earn from qualifying purchases.
MSP Radiator replacement
2003.5 Mazdaspeed Protege
Are the stock 2.0l protg's and MSP radiators the same? I thought the MSP was shorter due to the SMIC. I couldn't find a definitive answer.
If they are in fact different, does anyone know of somewhere that will something that drops straight in, no modification needed?
hornsfan10609
Certified Mazda Tech
2003.5 Mazdaspeed Protege x2
Yes the MSP has a shorter radiator, only solution if you have a SMIC is another OEM radiator or custom mount a half size Honda aluminum radiator. With an FMIC setup you can run the full length (yet smaller) regular protege radiator or upgrade to a Mishimoto, Corksport, AWR etc. Some companies make a replacement aluminum short rad that fits with the SMIC, Ron Davis I believe and they run about $500. OEM short rad is about $300 and should last another 10 years like the stocker.
Pez
you get a full size you have to get different hold down brackets then throw it all in and roll
Preferio
I break stuff.
Contributor
2003 Mazdaspeed Protege 1660, 2004 Winning Blue RX8, 2005 Mazda6
I had cooling problems at idle in the summer with the P5 radiator. And forget about AC.
hornsfan10609
Considering the Mishimoto is $250 it's the best deal, but I bet the OP has a SMIC still.
2003 mazdaspeed protege black mica
Added to this the mazdaspeed protege specific radiator is a dealer only item. Onlinemazdaparts.com or car-part.com depends on if you want new or used.
Preferio
I break stuff.
Contributor
Im fairly certain Worldpac has them too. I remember looking but didnt want to pay like $330 for it if i remember correctly. I already had a front mount and got a super awesome deal on a Mishimoto.
Thanks for all the input. I'm going to pull it and take it to a radiator shop to have pressure tested and hopefully welded. It definitely looks like the steam is coming from the front of the radiator, around the middle somewhere, which leads me to believe that it is fixable. I'd love to do FMIC setup, but money is a factor. I've built FMIC's from scratch before (on my 85 300zx turbo), but it was a headache to do. I'd prefer to just stick with stock and run this car until it falls off of a cliff.
Does anyone have a part number for the STOCK MSP radiator? Mazda-parts seems to only list the non-turbo stuff
2003.5 Mazdaspeed Protege, 1989 MX6, 1990 MX6
Any answer to this question? I hit some debris (someone lost their load - wood framing) on the freeway today and ended up with a hole in my radiator and the fan is also busted.
I've been searching for over an hour and the only thing I've come up with is that the MSP can't use the regular protege rad. I have a 100% stock car, and I need to get the OEM radiator ASAP. None of the parts stores list it and I can't find the part number anywhere.
Latest posts
Top
