• Welcome to Mazdas247. Membership is free and offers many benefits, please Click Here to learn more, thanks!
  • Mazdas247 is an Amazon Associate and earns from qualifying purchases.
MSP cdcv needed
97camaroSS e30 318is Spicy #1348
Anyone have a canister drain cut valve used in working condition? Mazda ZM0118741A
Im sick as hell of not being able to fill my gas tank. I'm replacing the purge solenoid valve under the hood due to code and the cdcv valve at the back of the car due to a small evap leak or blockage detected.
I'm hoping this will solve my gas filling issue. I have already replaced the filter/canister in back and have blown all the tubes I could get to.
On a side note. Does tbe MSP have a small metal flap over the fuel filler hole? The kind that flaps back as you insert the gas filler nozzle?
pcb
The Diagram Dude
2002 mazda protege 5
That flap should make no difference.
It's sealed by the gas cap not the flap.
Did you check your "air filter" ?
I have a P5 but your evap. is probably the same.
Check part #6 (air filter) to see if it's full of fuel.
Check part #7 to see if the vent holes in the side are plugged with dirt or crap.
Part #4 may also be full of gas. (I'm not sure what part you replaced.)
You don't have a leak, you've got a fuel blockage, that's why you can't fill the tank.
Weekly Poll: Interested in the new Mazda3?
  • Yes
    Votes: 3 37.5%
  • No
    Votes: 3 37.5%
  • I’d prefer a CX-30
    Votes: 2 25.0%
Top
