MS6 Build Number Thread
BoostedSpd6
Nip Slip!
Contributor
MazdaSpeed 6
ok guys here's the scoop, everyone knows that there was only a certain amount of MS6's made. Its not Official that we have Build Numbers like the MSP's do. With that said ive done some investigating along with the help of my cousin (hes a cop) and that investigation has led me to think that we indeed do have specific Build Numbers, although it was never made public.
so heres the format for the responses in this thread, help me figure out if its true!!!! 80% confident that we do have BN's
Year
Color
Last 6 digits of your VIN -- Your Serial or Production Number
Last 5 digits of your VIN -- Your Build Number -- Specific to the MS6's
Build Date-- can be found on the inside of your drivers door jam, theres a sticker where it lists your gross vehicle weight, upper left hand corner
As of 6/26/2010 All information will be posted in this Spread Sheet - Thank you Jenn and Carter for putting this together.
http://spreadsheets.google.com/pub?...15SHZsVXc&hl=en&single=true&gid=0&output=html
Breaking Down your VIN Number -- A big thank you to boost2dms6 for this information
Make/Model: (Digits 1-3) This breaks out the vehicle's make, model, and manufacturer.
Vehicle Features: (Digits 4-8) These digits identify the various features of the specific model — trim specifications, driveline options, etc.
Verifying #: (Digit 9) Determined through a complex mathematical formula that relates to the other numbers in the VIN; used to verify that the VIN itself is not fake.
Model Year: (Digit 10) Represents the vehicle's model year, which is not to be confused with the year it was sold or delivered.
Assembly Plant: (Digit 11) An internal digit that shows where the car was built.
Sequence Of Model Production: (Digits 12-17) These digits indicate the order in which the vehicle left the assembly line. This is effectively the Production Number
MS6 Specific Build Number: (Digits 13-17) These Digits are effectivly your Build Number and are unique to the MS6's
Using an autotrader VIN I figured out:
JM1GG12L171109207 09207
JM1 is obviously Japanese Mazda
GG12L are the features
1 is the check # and using this site VIN Calculator it verifys that this VIN is indeed real
7 is the production year which is 2007
1 is the assembly plant
109207 would be in fact our Production Number
09207 would be your specific MS6 Build Number
posted on 6 crew
http://www.6crew.com/forum/showthread.php?t=14832
posted on mazda 6 club -- pretty weak i cant link them over on here.. had about enough of that bullcrap
http://forum.mazda 6 club.com/mazda6-atenza/237939-ms6-build-number-thread.html#post3285190
Qwik6
Moderater
2001 Corvette coupe
You should add build date to the list. Are you going to post this in the other forums as well?
You guys know this already from the OP but here it goes.
Qwik6
2006 MS6
White Water Pearl
00604
Build date: 9/05
2007 Mazdaspeed 6 GT
You need the last 5 numbers, not 4...when I was looking for mine I was checking the VINs and it's pretty obvious that they increase up to about 11000 in order. Add the build date as well.
2007
Liquid Platinum Metallic
10403
Build date: 6/26/07
Yes, I have one of the last ones, it's about the latest VIN number that I found. :)
BoostedSpd6
Nip Slip!
Contributor
MazdaSpeed 6
ok ill add that info in.. mines 02717.. so thats good, as long as Taylor's is 00604 were all set..
BoostedSpd6
Nip Slip!
Contributor
MazdaSpeed 6
Ebay Listing Finds
2006
White Water Pearl GT
01227
2006
Velocity Red Mica
00672
2006
Velocity Red Mica
04454
2006
White Water Pearl Sport
02515
2006
Liquid Platnium Metallic
03281
2006
Black Cherry Mica
05697
2006
Black Cherry Mica GT
03232
2006
07769
2006
Black Mica GT
06484
Build Date 03/06
Qwik6
Moderater
2001 Corvette coupe
This looks promising. Unless an 07 comes up with a lower number than a posted 06.
BoostedSpd6
Nip Slip!
Contributor
MazdaSpeed 6
It is Promising.. this list confirms it
Autotrader List: i simplified it so it wasent so huge
2007 2007 2007 2007 2007
LPM GT VRM BM VRM LPM
09207 08698 09178 09877 08322
VRM LPM LPM BM LPM
08546 10293 09779 08503 09085
BM GT VRM LPM LPM BM
08991 08840 08666 09955 09541
2007 2007 2007 2007
BM BM VRM LPM
10563 (New High Number) 08794 08758 08510
2007 2007 2007 2007
LPM BM LPM VRM
10434 08655 09015 08631
thats just from 1 page on AT for 2007's
it leads me to conclude that somewhere between car 07769/08332 is the break line between 06/07 models..hopefully by the end of this we can get a closer number.. the new highest PN is 10563
Mazdaspeed 6 GT
Whats that thing underneath your matt on the passenger side.
Mine says Prime Number then something in Japanese on a plastic Plaque.
Mines 05/06
7615 last 4 of my vin
