Lug Nuts
I have a 2018 CX-5 with the 19" factory wheels; I recently purchased a set of factory 19" wheels from a 2019 CX-5 to update my vehicle. The seller included a full set of lug nuts with the replacement wheels. The new lug nuts are "acorn" style, while the old ones on the vehicle have a bulge on the bottom. Just wondering if the acorn style ones are typically used on the newer model wheels, or if I should mount the new wheels with the bulge type lug nuts.
Toronto, ON Canada
2017 CX-5 GT
The Mazda lug nuts on the vehicles have been the same since early 2006 from all of the Mazda vehicles I've owned.
If you are going from 2018 OEM to 2019 OEM, I'd use the lugs you currently have. Not clear if the 2019 owner changed from stock.
Without pics, not quite sure what the differences are. Mazda's are supposed to use Acorn style lug nuts and I'm referring to the seat of the lug as opposed to the overall shape.
Upvote 0
Virginia
2021 CX-5 White
I have not researched Mazda lug nuts, but from previous work on Acura and Hondas, it seems there are three types of lug nut seats
Acorn/Connical - a 60 degree conical seat
Bulge/Spherical/Ball - a hemishperical seat almost half a sphere
Flat/Flat with washer - a flat seat with a washer
Typically, as I learned, most "tuner" wheels come with the acorn/conical, and typically are sent with new lug nuts. These are typically the 5x114.3 mm bolt circle wheels. On heavier cars, that use the 5x120mm bolt circle, I have typically seen spherical or flat seat lug seats. But I have only seen a small sample of such wheels, including run flats.
Based on the Mazda CX5 Manual, it looks as if Mazda uses the traditional acorn/conical lug seat.
My Subaru WRX uses the same acorn/conical seat, which I believe to be the same as the Mazda. Our Mazda is in the body shop right now, so I cannot tell you for sure.
For my Subaru WRX winter wheels, Motegi MR118, they use conical lug seats, but the lug nuts that came with the wheels also a need a special thin wall splined socket. All came from Tire Rack
I just thought I would post this for those interested in crazy details
Upvote 0
yrwei52
Contributor
Plano, Texas, USA
Great info! Yes, our CX-5 uses the traditional acorn / conical lug nuts.
Upvote 0
