Just another yellow P5 build...
Jackie chan
Team Pro5
Pro5
Hey guys.
Things seem to be getting deader by the day for us protege fans. I figured since we haven't got much less to lose, I may as well make a build thread! I'll start by saying hi, my name's Ben. My protege has been my daily driver, project car, and only car since '09! I've been on here and other protege forums for a long time, mostly just scouring the web for info, but you may have seen me answer the occasional question from time to time. I haven't made a build thread until now, because figured i'd bore you guys, haha! But in all seriousness, since attendance has dropped and a lot of people have stopped caring about proteges, I guess I just want to do my part in reigniting the flame for someone else.
Whelp... I guess we'll start off with some pictures to Give you guys an Idea of what I'm talking about.
Now I guess I'll follow that up with a Mods/Maintenance/Parts list.
Engine/Drivetrain
-Wiseco 9.0:1 Forged Pistons .020 over
-K1 Forged Rods
-ACL main, rod, and thrust bearings
-Split Second AFC
-Deatschwerks 440cc injectors
-Walbro 255lph fuel pump
-Deadbolt Zilla TD05H-18G turbo
-Hiboost Turbo Manifold
-Hiboost Downpipe
-Hiboost FMIC
-Arashi adjustable Wastegate actuator
-Turboxs Blowoff Valve
-Ported/polished 626 Intake Manifold
-Ported/polished Throttle Body
-Turbosmart Manual boost controller
-Signature coated and bypassed oil pump
-Peterson External oil PRV
-Mishimoto remote oil thermostat
-19 row Oil cooler
-Oil filter relocation
-A/C Delete
-AWR Motor mounts all around
-Charcoal Canister Delete
-Corksport SS clutch line
-Corksport Bronzoil Shifter Bushings
-Corksport 3rd Link Kit
-Torque solutions Poly stabilizer Bushing
-Kartboy Shifter
-Greddy Counterweight Shift Knob
-2.5 Straightpipe turboback exhaust
-ACT Heavy Duty street strip Clutch
-Maf Relocation
-Atmospherically Vented Oil Catch Can
-MSP mbsp
-jdm 626 valve cover
-1.8 coil conversion
-Feeda 2 Row Radiator
-CR3 Radiator air diverter panel
Suspension/Wheels
-Yellowspeed Coilovers 24k/24k
-SSR Veilside Marriotts 17x9 +15 front, and 17x8 +29 rear.
-Mazdaspeed Racing Harts 17x7 +55
-Wilwood Superlite 4 piston Calipers
-Baer 13" Slotted Front Rotors
-AAC Billet rotor Hats
-AAC Caliper brackets
-Corksport Front strut tower brace
-ARP extended studs
-Mazdaspeed 25mm front swaybar
-Whiteline Adjustable Front Swaybar End-Links
-Progress Rear Swaybar
-SuperPro polyurethane front control arm bushings
-AAC Adjustable Lateral Links
-AAC Adjustable Trailing arms
-Mx6 rear strut tower brace.
-Muteki Lug Nuts
Interior/exterior Appearance
-Corbeau fx1 Pro seat, side mounted, no sliders
-Schroth enduro 6-pt Harness
-47" harness bar
-Autometer Triple Pod pillar
-AEM Wideband Air/Fuel Gauge
-AEM oil Pressure Gauge
-Glowshift Boost, Water temp and volt Gauges
-Zada Tech LCD Oil temp Guage
-Jdm Tail lights
-Haima Happin upper grill and emblem
-Euro 323f badge
-Door moldings deleted
-Black headlight Bezels
-H1 projector retrofit in P5 housings
-RGB demon eyes
-Low beam 6000k hids
-Hid retrofit Stock fogs 3000k
-Black Rear Valence
-Mazda 6 rear Wiper
-S2000 Antenna
-Smoked bumper markers
-Mazdaspeed aluminum door sills
-Mazdaspeed Aluminum pedals
-Suede Wrapped A&B pillars, Glove Box, panel underneath steering Column.
-Suede Shift Boot
-Pioneer DEH-80PRS Head unit
-Pioneer A-series door speakers
-Fiberglass tweeter pods with JL tweeters
-10" Rockford fosgate sub
-Mazda 2 HVAC knobs
-Android tablet Retrofitted into Center console
-Battery relocation
'02.5 Mazda Protege5
Wow, looks great so far! More pics?! That interior looks pristine. I can always appreciate someone who strives to keep they're car looking clean as well as keeping it physically clean (thumb)
Jackie chan
Team Pro5
Pro5
Just got a ze valve cover that is in the prep phase. And I'm going to be shaving some things off of it. Also ordered some 1.8 ignition coils and a set of cb7 accord plug wires. Also working on the other two Racing Harts for the front. Making stuff happen.
2002 Mazda Protege5
Can someone explain the 1.8 coils conversion to me? What's the difference/pros/cons?
Also, do you have spacers behind that rear set of Racing Harts?
Jackie chan
Team Pro5
Pro5
20mm spacers on the rear with around 1.5 degrees camber an 215/45/17 tires.
1.8 coil conversion is mostly just for looks, but a plus is you get the coils off the top of the engine, less heat promotes longer coil life. Some people have noticed other improvements, and that would be great, but I'm not expecting it to feel any different.
Jackie chan
Team Pro5
Pro5
It really does look pretty good. I'm the happiest ive ever been with it. Its been through a couple of reincarnations, but this is the best so far.
Looks amazing man!! Love all the attention to details, especially the engine bay. I know it's a work in progress, but looks beautiful already. I also really dig the custom tweeter surrounds, look snazzy. Well done! (thumb)
2003.5 MazdaSpeed Protege, 2002 Protege 5, 2003 Protege ESGT
Damn man. you have one nice clean p5... im jealous!
Jackie chan
Team Pro5
Pro5
Thanks guys. Got a couple more pictures today.
You can see my huge dent behind my headlight. Other than that and a small dent in the middle of the hood, thats pretty much it for damage.
Jackie chan
Team Pro5
Pro5
Here's what i'm currently working on:
These are old, cut accord wires just for mock-up purposes. Since the lengths are perfect for my coil mounting choice, i'll be using a slightly modified set f22 plug wires.
JDM yo haha... I seriously might keep it though...
And there was some mounting points on the front of my fsze valve cover that need to be shaved along with some other less important stuff.
Here is the ze coil bracket that I cut up and will be using with 1.8 coils. I would've used the ze coils, but one is all chewed up from something.
