Interchangeable parts for newer CX-9 (2017-2019)
2019 Mazda CX-9 Touring Premium Snowflake White Pearl Mica
Hello All-
Does anyone know if the newer Mazda CX-9 has some interchangeable parts? Like for example headlights and rear tail lights and such.
Thank you in advance!
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
Yes and no. Some components will be plug and play, while others will not. Specifically, if you wanted to replace a 2019 headlight with a 2017 headlight, you could, as long as both headlights came from Touring trims. You cannot easily replace a 2019 Signature headlight with a 2017 Touring headlight because the Signature's headlight has LED accents, among other things. It would require some wiring work at the very least.
Same goes for stuff like the illuminated grille on the Signature, the "inner" tail lights on the GT and Signature, front and rear bumpers (Sig comes with parking sensors on front and rear). Some stuff is exactly the same across all years and trims though, like the plastic fender guards, the chrome trim pieces (minus the front grille), and roof rails.
Thank you so much sm1ke!!!(thumb)
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
No problem! Is there anything in particular that you plan to upgrade/swap out in the future? I know you've expressed interest in swapping out the headlights, but what about the inner tail lights or the illuminated grille?
