Don't jack the car up to install swaybars. Should be installed on ramps...
And it depends... Mine adjusts so it can go on either side depending on how it is adjusted.
EDIT...UNDER!!!! thought you were asking about where the endlinks would go...Maybe I should see the picture first...and...You should install the swaybar on ramps...it should be installed with weight on the wheels/frame.
