How often brake pads needs to be inspected - every 2 yrs or 30k?
mazda
Not fluid flush
My Acura Integra needs brake fluid flush every 3 yrs. In that process they inspect the brake by removing it.
M5 has long life fluid - so how often should have brake inspected on M5?
90210
2012 CR Mazda5 Touring
2012 Mazda5 Touring
My Integra GSR has 577k miles on it. Bought it new. I brake flush every 60k miles.
My Mazda5, font brake pad 72k miles. Rear still original. Car has 118k miles. Flushed it once.
My race cars i flush yearly
2012 Mazda5 Sport AT
I drain and fill my brake fluid every year. It takes under an hour and costs like $10. I also lube the caliper guide pins and check the rest of the brake components. I put new rotors and pads on all four corners around 75k or so (I forget the exact number) and am at 127k right now.
Epping, NH
2012 Mazda 5
I give the pad thickness a look every time I rotate the tires which is 7500 miles. The also get checked annually during state inspection.
Still have the original pads at 108k. I'm planning on replacing them in about a month when it warms up a bit here.
2013 Mazda5 Sport
Replaced my pads around 60K. Check them each time I rotate tires. I tend to do them a bit on the early side though. Try to avoid doing any repairs in the winter. Cold weather makes things harder to do.
2012 Mazda 5 Touring WP, '18 Passat SE w/Tech, '17 Polaris 570
I did my fronts @ 30K, Fronts & Rears @ 60K and I did Brembo pads With Stoptech rotors the 2nd time around. Now @ 92K looks like I still have about half life left on the pads.
Top
