charlietuna
- Mazdaspeed Protege
Could anyone let me know if they have either of, or both of these items on their Mazdaspeed Protege? if so, what is good or bad about either or both? Any help would be greatly appreciated...
ChopstickHero said:they would probably make your car sound badass.
i have the injen CAI and that makes the turbo sound badass. i can imagine with a greddysp2, it would sound even better. from what i've read and heard sound clips, it's like the stock exhaust at idle and low throttle, but really growls at WOT.
charlietuna said:did you do the install on the intake yourself? if you did, was there any custom fabricating to do?
chowhoundMSP said:I just ordered my sp2, did some shopping around.
if you are looking for a good price, try racezero.com, they are running a deal for free shipping on orders over 250, so you pay like 6 bucks for handling fees, instead of 50 bucks like most other places.
best deal i could find, if you are looking to buy.
ChopstickHero said:install was easy. brand name intakes usually come with instructions. my injen did. it wasn't the best, but it's not that hard. the only thing i had to do was drill a hole in a bracket (which the instructions told me to do). no need for custom fabrication, completely bolt on.
charlietuna said:the dilling was just through an aluminum plate?
ChopstickHero said:drilled a hole through the coolant resevoir bracket. did this to to secure it to the frame and allow room for the coolant bottle. you'll understand when you see it or do it.
charlietuna said:Could anyone let me know if they have either of, or both of these items on their Mazdaspeed Protege? if so, what is good or bad about either or both? Any help would be greatly appreciated...
grcuadros said:ill let you know in a few months. thtas the setup im planning for. anybody know the size piping for the sp2? thanks.
DAWIV said:I have the SP2 and an Injen. I love both. The piping diameter is not an issue. Afterall, the MSP is not exactly a 300-400hp car. The Greddy sounds great when you take off for sure. No drone at highway speeds and it can be rather quiet under normal driving situations. The intake is very easy to install. Just take your time and jack the car up, it will be easier to install the filter and position the clamps at the turbo. Make sure you disconnect your negative terminal prior to starting. Becareful with your MAF and don't knock it around, You'll have to move the drivers side splash guard out of the way when installing the filter.
DAWIV said:I don't think it matters which CAI you go with. Since they are more style over substance, then why not go with the one that enhances your engine compartment best. I bought the Injen because it was the only one out at the time.
DAWIV said:I never dynoed my car. The Injen was my first mod. Even before the flash, I noticed a difference. They both seemed to smooth out the acceleration a bit and allowed more top speed. I used to commute over 150 miles a day on the interstate. I also have a 2.5 catless downpipe which I put on after the Greddy SP2. That mod didn't translate in to a seat in the pants difference, but its crucial if you are going to up the boost.
Have you seen the Import Racer article that tested mods in stages? They used a catless downpipe and Greddy SP2 and reported 12whp and 14tq gains over stock. They also added an SRI and reported 8whp and 4tq gains over the factory box. Turning up the boost to 9.4 psi netted the biggest gain, 26whp and 24tq. You can find a copy of the article in an old thread on here. I have a TurboXS dual stage mbc, and that is by far my most effective mod for big power. I keep stage 1 at 6.9 psi for traction and stage 2 under 10 psi, unless I am using Sunoco GT100 race gas.
