Gen 1 vs Gen 2 CX-5 damper/shocks interchangeable?
Northern VA
2014 CX-5 AWD
Looking to see if I can get sportier dampers/shocks for my 2014 awd, I noticed that Bilstein b6 shocks are available for 2017+ models but does not list 2013 - 2016.
Does anyone know if the shocks are interchangeable? Koni special active shocks lists the same part numbers for both gen1 and gen2 so I am hopeful but my search skills are failing me at 2am.
If I don't end up with coilovers then I will most likely replace the stock dampers with bilstein b6 or the koni special active dampers.
Also interested in seeing if the OEM 2019+ CX-5 dampers/springs are compatible in a 2016. The newer CX-5's ride much nicer.
