fuel cleaner
Occupied Calif.
2019 CX 5 GT-R
Use top tier gas, add a dose of Marvel Mystery Oil to the gas tank every couple of thousand miles and add a bottle of Techron to the tank about 500 miles before each oil change. The amount of money spent is about like a couple of fast food meals so pretty negligible. What is a waste of money is letting a dealer do an expensive "fuel injector flush & service" when doing the steps above will keep the injectors clean.
I haven't had my CX 5 long enough to see if there are any issues with the float in the fuel tank that measures the level giving flaky readings, but in my past 370Z it was a known problem. The addition of a few ounces of Marvel Mystery Oil to the tank apparently had some type of lubricant or solvent qualities that would solve the erratic readings for a couple thousand miles until it came up again. So it isn't just snake oil.
so why the manual states using fuel cleaners only in target countries?is the skyactive engine sensitive to fuel additives?
Soon to be 2.5T CX-5
Techron to the gas tank before every oil change? no Thanks.
I'd rather have the fast food meal, it will do more good. Dammit, Chic-Fil-A is closed on Sundays. Guess I'll keep the money for something way more useful.
2017 Mazda CX-5 GT, 2016 Mazda6 iGT, 2014 Mazda3 sGT hatchback
Fuel additives do not help direct injection engines as much as port injection ones.
It only help clean injectors, but fuel of most name brands also does.
They also contain cleaning detergent.
Avoidin Deer
Zoom Zoom, baby
Contributor
Central Virginia
2019 CX-5 Reserve
-#1 customer ranking among fast food restaurants.
-Higher per-store sales than McDonald's while being closed half the weekend/every weekend.
Mazda needs to poach a couple of their marketing guys.
i know what the fuel cleaner clean and dont on a di engine,been in the wall nut blasting stage in my previous car,im asking why mazda forbids using it in the manual,
tnx.
13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
tnx.
Say what?
No need to spend hundreds to blast nuts into skyactiv Mazda engines. See Felix Dan's video of DIY cleaning. That said, we just do long daily commutes so not needed for us.
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
tnx.
Say what?
Allow me.. "I know what the fuel cleaner doesn't clean on a DI engine. Carbon build-up was so bad on my previous car that I would have needed to get the intake valves walnut-blasted to clean them. I'm asking why Mazda forbids using fuel cleaner in the manual for my current car. Thanks."
To answer OP's question, I think its just CYA on Mazda's part.
tnx,
what is cya?
Top
