1997 Volkswagen Gti VR6t T-Red w/ AC
Miles: 145K on body new fully built head hevy duty internals
Body: 9/10
has some blemishes..nothing bad for a 14 year old car!
New badge less grill
15% tint all around
New oem key cylinder kit on drivers side installed
New BF Goodrich g-Force tires wrap around some euro spec Rx-II very nice
Rear finders rolled no damaged
Brakes: 9/10
About a year old
Front slotted rotors
Rear drilled and slotted rotors
Rear stainless steal brake lines
Engine: 9/10
15lbs daily
Polish intake painted heat red
Metal valve cover polish
DSR 256 cams regrinds
New fully built head heavy duty
New timing chains
New water pump
New thermo stat kit
SAI plug 42
ARP head stud kit
All new gaskets and seals
Fresh coolant
2.8L Turbo (kinetics stage two)
38mm external wastegate 13lb spring
Full front mount
New k&n filter
New throttle body (129k)
New C2 updated chip for dsr 256 cams stock COMP and #30lb injectors
3in all the way needs a muffler right now. i will be getting one VERY SOON!
NGK plugs
Mobile 1 10w40
Has A/C and is ICE cold!!
Interior: 9/10
Everything works but cruise no leaks from sunroof
Transmission:
Fresh Royal Purple fluid
New rebuilt Transmission at (133k)
New clutch Spec stage two at (129k)
Spec 13lb flywheel
New g60 trans mount
Pulls hard
Suspension: 9/10
New FK coilovers yellow
Both front strut bearings
Wheel spacers 10mm in front, 15mm in rear
New inner and out tie rods
New rack and pinion
New stab links
New front wheel bearings
Rides great
not really looking to sell.. will entertain legit cash offers..
more looking to trade for a 03-03.5 Mazdaspeed Protege.. trade must have:
Welded LSD!
upgraded clutch!
upgraded motor mounts
upgraded intercooler
upgraded turbo would be nice!
Wideband/EBC/Boost Gauge
exhaust system!
upgraded WGA
upgraded bpv/bov (if bov must be relocated already)
not wanting one thats burning any oil..
TUNE!!!!
prefer forged bottom end
must be clean title!
prefer less than 100K miles
really looking for spicy orange or yellow metallic.. will also consider a black mica! not really looking for the silvers unless its a heck of a car
i am really downgraded my performance here! so please make it worth my while! my car with another 1200 invested would easily be in the 500 whp range (head spacer, 42 lb injectors, new c2 tune)
will also consider other 4 dr turbo cars on trade.. just let me know what you have~!!
Body: 9/10
15% tint all around
Brakes: 9/10
About a year old
Engine: 9/10
15lbs daily
New timing chains
New water pump
New thermo stat kit
SAI plug 42
ARP head stud kit
Fresh coolant
Full front mount
New k&n filter
NGK plugs
Mobile 1 10w40
Interior: 9/10
Transmission:
Spec 13lb flywheel
New g60 trans mount
Pulls hard
Suspension: 9/10
New rack and pinion
New stab links
Rides great
Welded LSD!
upgraded clutch!
exhaust system!
upgraded WGA
TUNE!!!!
