2016~2021 Difficulty with OEM CX-9 roof rack cross bars
I was wondering if there was anyone out there who purchased a 2021 CX-9 with the factory roof cross bars already installed. I wanted to take the cross bars off, however the bolts must have been installed incorrectly as the bolt will turn but not loosen. It feels like the nut inside the roof rails which the cross bar bolts to has detached internally. It doesn’t help that the bolts are a pain to get to as well. Has anyone else encountered this problem?
2021 CX-9 GT
FWIW .... I ordered the roof cross rails and will be installing them next week when they arrive. I’ll let you know if there’s anything quirky about how they are installed.
I have another post about why I swapped the OEM crossbars for yakima bars. I took mine to the dealer to have the OEM bars removed. I put a wrench on them and was too afraid to strip them. They did it for free.
2021 CX-9 GT
I installed the cross bars and it was tedious because of the position of the Torx screws but the screws engaged positively and did not feel as if they were cross threading. If you have a swivel socket for the bit, it will be much easier to try backing them out rather than using an Allen wrench.
Are the screws stripped on both sides? You could try removing one side and maybe the stripped screw will pull out from the other side? If not, you might have to tap it and drill it out.
klwdallas
2019 Pearl White Touring with Premium Pkg
I didn't notice anything unusual when I installed mine this weekend. Just a simple bolt into a hole.
Latest posts
