Differential rear mount replacement
jimmyswimmy
09 CX9
Hi,
I have an 09 AWD CX9 and need to replace the rear differential mounts. There have been a couple of useful threads but I was hoping someone had done this and remembered how much of a pain it is. I can afford to spend a couple hours out there working on the car but the family get antsy if I spend all day on it - in which case I'd rather pay the shop.
The shop told me they'd take out both axles... was not impressed when I heard that. Can I just put a jack under the differential and press the bushings out? It sounded like the Russian guy destroyed them in place... a little leery of that approach too.
Thanks in advance.
https://www.mazdas247.com/forum/showthread.php?123845262-AWD-Rear-Diff-subframe-bushings
https://www.mazdas247.com/forum/showthread.php?123853918-Write-up-for-rear-diff-bushing-removal
https://translate.google.com/transl...p://www.radioscanner.ru/forum/topic12415.html
Hi,
Thanks in advance.
No need to remove the axles, you need to disconnect the drive shaft, pull the bushings out and press the new ones in. There is not a lot of space to work with
I have a noise from under the CX 9 and thought it might be wheel bearings but once I got under there I found that the differential bushings were shot and the unit was sloppy and moved around with a turn of the wheel. My question is are most people doing this repair themselves buying complete mounts with new bushings or just buying the bushings and installing them in the original mounts? Are the bushings a job for a shop press or can they be handled in the driveway with a C clamp or bench vise? I'm new to this forum. Just bought a 2010 CX-9 in November for my wife and she loves it! Thanks to any who can find time to reply.....
Anybody ever done this repair? I ordered the bushings and am waiting delivery. Why have some suggested that the driveshaft be removed? I could use a little help from anyone with some experience with this.
Yeah, I did not so long ago. It wasn't so bad. Here is the link to the video
https://youtu.be/nnndbbPBzdc
Looks like your video was removed due to account termination.
Any other place to see it? I was told on my last service that my rear diff mount was cracked. I forgot to ask for specifics as to which specific part was broken. I have to find time to go under and take a look but if there are any other pics or videos to reference that would be great.
@specrocz, Did you end up doing this repair yourself? Did you have to pull the axles? Drive shaft? Were you able to press in the new bushings? Did you do them yourself of have a shop do them?
-Kyle
-Kyle
Yes I did it myself. I supported the differential and pulled the mounts and pressed new bushings into them. The price for the bushings was around $19 and new mounts was much more expensive but I can't remember exactly how much. It wasn't hard at all and I did it on a snowy driveway in 10 degree weather.
@specrocz Where did you get the bushings, I'm going crazy trying to find them.
Latest posts
