CX-8 key fob battery replacement problem
CX-8 2020
One of my 2 key fob batteries has gone flat. Car is only 4 months old. It's different from my CX-5 and can't work out how to get the battery out to replace it. HELP!
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
They usually put this type of information in the Owner's Manual. Are you in Japan or Australia? I tried searching the Japanese CX-8 Owner's Manual and found it here, but I can't read kanji. The Austrailian CX-8's Owner's Manual is available via MyMazda.com, but I can only register for the NA region, so I can't check MyMazda AU to see if their manual details the process.
With that said, if your keyfob is the same as the 2018 CX-9 keyfob, you can use this link for reference.
If all else fails, just bring the keyfob to your nearest Mazda dealer and they can help you figure it out.
Upvote 0
CX-8 2020
Many thanks for the reply. The CX-8 key is different from the CX-9 link you sent (and different from my old CX-5 too). Looks like a trip to my Mazda dealer. Rang and they said 'it's easy when you know how'. Isn't everything?!?
Upvote 0
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
Lol yes that can be true. Can you post a picture of your keyfob? Does it look like the new keyfob style in this picture?
Upvote 0
Top
