Cooling fan keeps running after turning off engine
2016 CX-5 AWD Touring
During the last three weeks, my CX-5 twice had the cooling fan running after I turned off the engine. The fan ran for about 1-2 minutes. I know it's normal to have the fan keeps on running if the engine is hot, but I'm talking about driving in 25-30F of Minnesota winter, my garage is not heated, usually stays about 45-50F. The trips were short, about 5-6 miles. I noticed that I might have had the heat cranking up a little too hot in the car, but that shouldn't affect the engine temp, right?
Is it something to worry about?
2015 CX-5 GT AWD liquid silver
I wouldn't worry. Mine has run the fan when I stopped in the garage. I can't tell you what causes it other than a sensor someplace in or on the engine is hot.
2016 CX-5 GT w/tech FWD
Your coolant low? This was happening on my moms Lexus and we realized the radiator was 3 quarts low. There was a leak...
Check your overflow reservoir. When hot, is it near the max line?
CX5 GT-R
Normal. ..now if mazda could just make an oil pump thay does the same thing for the next RX platform so thay people who don't understand machinery can be happy, too!
2013 CX-5 Touring
I wonder why some people see this and others don't. In Houston's 100 degree summers, I've never seen my fan keep running after I turn off the engine.
craigo
Contributor
2014 CX-5 GT FWD, 2015 Mazda 3 Touring
I've only seen this after some track laps and running it hard. Is OP sure its the fan? There's another device in there that makes some noise after shut off.
Yeah, it's the fans. I opened the hood and saw two white fans blowing right behind the grill. I've check the coolant when the car cooled down, the level looks good right between L and F marks, don't see any leakage neither.
I had the car since October, but didn't notice the fans keep on running until the last three weeks. And it's not consistent, only twice so far, randomly but it might relate to how I crank up the interior heat, or it might be part of the break-in process. I'll keep paying attention, maybe I'll see a pattern. Thanks all for your help.
GA prior 16 CX5 GT
20 CX5 GT + Prem
The AC compressor must be on. I think if you turn it off the fan will not run when you kill the engine...
In this freezing weather, I think I can totally tell if the heat is not on, let alone telling if it's blowing cold air :) Regardless, I'll try turning on the AC and see if I can reproduce the behavior. Thanks.
The compressor will run if defrost is selected.
GA prior 16 CX5 GT
20 CX5 GT + Prem
^^ What does that have anything to do with it?
On most systems if the AC compressor is on the fan comes on to force air through the condenser so it will cool the hot discharge out of the compressor and it stays on for a bit after shutdown to cool the discharge...
2016 CX-5 Sport AWD
I have never heard of that before. My fan stays on after shut down after a spirited drive.
Top
