So, when I got out of my car @ work this morning, I heard what sounded like a a bubbling radiator/coolant. I popped my hood, and saw coolant bubbling and leaking out from the front left corner of the block. It's about 1" in front of the t-stat housing. It looked like it was not the t-stat housing gasket, but the piece farther in from the t-stat housing. I found it odd that it was leaking from this location... BTW, temp was normal on the drive to work, but it was a short (10 mins), easy drive...
It's probably important to note that I drained all my coolant on Sunday & installed Samco radiator hoses (upper & lower). I don't see how this would really cause this leak, but seeing as they are the same system, maybe these hoses increased flow and put added pressure on a gasket that was already well worn?
Anyone else had a leak here? Is there a gasket right there that I need to replace? I'll go consult the manual as soon as I post this, and I guess I'll just buy a new t-stat gasket & I guess there's another gasket from the piece to the block, idk? I'll drain my coolant again and replace those gaskets. Hopefully that will fix it.
If anyone has some insight on this, let me know... I didn't get a chance to look at it for long this morning, as I had to get inside for a meeting first thing this morning.
